Texas Instruments TI-83 Plus Calculator Logo
Posted on Nov 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fractions on my texas tI-83
How do i get the caculator to use/do fractions
k24674
Level 3:
  • Texas Instru... Master 8,093 Answers
  • Posted on Nov 02, 2009
k24674
Level 3:
Answers
8093
Questions
0
Helped
4671857
Points
21595
You get access the command by pressing [MATH][1: |->Frac].
If you want enter a fraction and keep it as a fraction (albeit a reduced one)
key in the number then the sequence [MATH][1: |->Frac]., then [ENTER].
Practice : 27/48 [MATH][1: |->Frac] [=] gives the reduced form 9/16.
While this fraction is still in [ANS] memory, you can press [MATH][2: |->Dec] [=] to get the decimal value 0.5625
Hope it helps.
Can the ti 68 do fractions
My Ti 83 does fractions (once you go into "math" then "fraction>" it converts a decimal to a fraction) And the Ti86 came out a year after the TI83, so that's going to be a yes.
I'm trying to find the fraction button on my texas instrument ti 83 plus calculator and cannot find it
There is no "fraction" button on the TI-83 plus. You will have to press the divide key (2 buttons below the CLEAR key) and then use the parentheses (immediately to the left of the divide key) to tell the calculator the correct order of operations. For example, "1/3x+9" means ".333333x+9", but "1/(3x)+9" means the "x" goes on the bottom of the fraction.
1helpful
How do you put a fraction into a TI-83?
The TI-83 doesn't really work with fractions. You can enter a fraction as a quotient. For example, one-third can be entered as (1/3) by pressing ( 1 / 3 ). However, the calculator works with numbers in decimal format. You can convert a result to a fraction by using the >Frac command, available by pressing MATH 1.
2helpful
How do I get a fraction as an answer instead of a decimal?
The TI-83 can only convert a small range of numbers to a fraction. To try so, use the >Frac function on the MATH menu. Press MATH 1 to invoke it.
How do i multiply fractions on texas instrument TI-83 calculator
The division sign acts like a fraction on the ti-83; to multiply two fractions you may want to wrap them both in parenthesis to get the order of operations correct.
Vote early and often
1helpful
2helpful
Fractions
Use the >Frac command in the MATH MISC menu to convert a value to a fraction.
2helpful
2answers
How do u do fractions
Enter the numerator then the division key and the denominator. Before pressing [ENTER], press [MATH][1:=>Frac] [ENTER]. The fraction will be displayed reduced.
27/48 [MATH][1:=>Frac] ENTER] yields 9/16
4helpful
TI-83 Plus calculator--fractions
just type it in, e.g. 1/2 or 3/5. if you want to have answers display as fractions, press [MATH] ENTER.
TI-83 Plus Silver Edition problem
Use a paperclip (tiny hole on back of caculator) and reset.
JC
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
