I have kenmore electric dryer model # 110.60942990. When I turn it on, it doesnt blow hot air, only cold air. What could be the problem?
SOURCE: I have a Kenmore electric dryer mod. # 110
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
SOURCE: Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
SOURCE: electric dryer blowing cold air
You either have a blown fuse, breaker, burned out element, wiring that has come loose. They all can be checked within 5 minutes. However, I believe it is in the thermal fuse which is located below the top of the dryer. You can access that pretty easy though. To check it, just bypass it and put the 2 wires together and see if it runs. The fuse is only 15 dollars or so. I am assuming you have an electric dryer.
SOURCE: kenmore 110 60942990 dryer works but takes 3 hours to dry a load.
Venting. When elements or thermostats burn out it is almost always caused by venting restrictions. Vent is plugged with lint, smashed(usually from the dryer being pushed back to far) vent run is too long, or nylon stocking on vent outlet. Also check to see if you can pour water through your lint screen. Sometimes fabric softener builds up on the screen and restricts the air flow. Scrub your lint screen to get this build up off. Good Luck, Appliance Specialists
SOURCE: I have a Kenmore 110 60812990 80 series dryer
bad heater box fuse,get the model number from inside the dryer door,and go to your local appliance parts store and give them the number and they will get you a thermal fuse kit,remove the back of dryer and you will see the heater box on the right side
