Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
My Fisher and Paykel flashed a F2 error code. What does it mean and what can be done to clear it.
Posted by Rick Senior on
  • Rick Senior
    Rick Senior Nov 01, 2009
    Just to clarify the error code, it is an F2 Error code with a wrench. What can be done to clear it
Sam
  • Fisher and P... Master
  • 3,247 Answers
F2 error means motor problem. This could be due to several reasons. The most common is grime going in from the drain filter and getting stuck around the motor rotor cavity.
Follow instructions in your user guide to clean the filter plate. At this point you can take the rotor out and clean the cavity. The rotor can be pulled out carefully without pressing too hard on the impellers.
If this does not help then try cleaning the connecting link between the drain filter and motor cavity. You will need a thin stiff wire for this.
Finally if nothing works, the rotor might be broken and needs replacing.
Posted on Nov 10, 2009
1helpful
2answers
I have DW60CDX2 , Turning on but buttons are not responding when I pressed buttons?
from what I'm seeing for the dishwasher, an E1 error means that the door is not properly closed. So, please look at the door of the machine to make sure that nothing is broken or that the dishwasher isn't too full. Thank you.
1helpful
I have a Fisher & paykel fridge freezer . It is showing an error f2 , any suggestions please
Fisher & Paykel Fault Codes
Fisher paykeldishwasher
F2Motor problem
F3Temperature sensor failed.
F4Faulty temperature sensor or element
F5Lid fault
1helpful
On the 2nd draw will start washing but not even a minute flashes the F2 error and stop washing, what this means?
Hi Francesca, The link below is a short youtube video on how to simply fix f2 on your fisher and paykel dishwasher.......CHEERS..
https://www.youtube.com/watch?v=qP_X9iG0f-g
Fisher and Paykel MW512. Error Code can't be determined. Light 8 flashes as does lid lock light
exactly which lights are flashing?
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/420983_Smartdrive_UC_UD1.pdf
My dishwasher is displaying an F2 error code, how do I clear it?
This means the rotor at the base of the drawer is causing some fault. Check the cavity after taking the rotor out and see if there is anything obstructing. Usually a seed or bone fragment. if problem persists you will have to replace the rotor.
see this Youtube video for removing rotor. New rotor is about $90.
F2 code on my fisher paykel
Assuming you have a drawer unit, the F2 eror means there is some erro in the pump motor circuit. It is likely the motor speed sensor may be faulty or dirty. Please provide full model number so that I can check which part I am mentioning. May I ask why you needed to replace the pump assembly in the first place.
My dishwasher is not working and has an error code of F2. How can I fix this problem?
F2 means that your rotor isn't moving properly and will need to be replace or it needs to be removed and check for something blocking it. Below is a link to a video that will show you how to take your dishwasher apart and repair your Fisher and Paykel unit.
Good luck.
2answers
I have a f1 come up and a f2 on my dishwasher what is it
f1 = Flood Code
This means that the dishwasher most likely has a leak
There is a float switch in the bottom of the machine and when water gets down there it trips the code
F2 = Roter not moving
you can remove the basket and spray arm and pull the roter out and make sure its clean and give it a try.
1helpful
About one minute after pressing start, all stops and F2 flashes. Need a solution before tearing into it.
Please provide model no. of your fisher and paykel dishwasher.
The F2 error usually means the rotor at the base of the dishwasher is either faulty or is unable to move due to food particles getting caught.
Happy to help further if you can provide model no. and if double drawer then in which drawer this is happening?
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Marvin
Marvin
Paul Bade
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
