Question about Jet 1HD Power Electric Wheelchair
Who do you replace the batteries
How do you replace the batteries on a 1 hd wheel chair?
Posted by alaborhines on
oregoon
  • 175 Answers
I've never heard of a 1HD wheel chair and I've been at this for a long time. Assuming it's a Pride Heavy Duty (HD) then you would start by disconnecting the joystick from the base by unplugging it at the rear of the base, and cut any nylon cable ties holding the joystick cable in place to the base. Then remove the seat. Depending on the model, you can do this either with a lever on the side that unlocks the seat to allow it to pivot. If yours has this lever, unlock and turn the seat very slightly, then lift up with a **** with both hands and it should come off after a few good tugs...some need more coaxing. If the seat is a "post-mounted" seat, you will see it attached to the base with four posts at each corner and there should be a retaining ring holding the posts together. Remove the pins and lift the seat off(helps to have two people). It may have a rear locking seat where you release the front mechanism under the front of the seat and tilt the seat up, then slide the seat slightly forward and lift up. These are the only three ways I've seen a seat attached to a base. Once the seat is off, you need to remove the shroud covering the batteries. Many are simply held on with velcro, so if you don't see any screws holding the shroud on, just lift up on it and pull it away from the velcro. If there are screws, remove them to lift off the shroud. Now you will see the batteries. Disconnect both of them and move the wiring out of the way. Remove the front battery, then the rear, and replace with new batteries and reassemble. The seat and batteries are pretty heavy, so it is nice to have a helper.
Posted on Jan 08, 2010
New batteries new battery harness still 3 red bars and two yellow bars flashing what else could it be
[PDF]Pride Jet 2 Hd Owner's Manual - Scootaround
www.scootaround.com/.../manuals/pridemobility/Pride%20Jet%202%20...
The symbols below are used throughout this owner's manual and on the power chair to identify ... Jet 2 HD www.pridemobility.com. 3. TABLE OF CONTENTS.
Sep 28, 2015 | Jet 2 HD for 350 lbs, Power Chair,...
Wheel chair will not turn left
Check for intermittent left motor wire connectivity at 4-pin connectors red and black wires. This is a common issue with this model: motor power wires break inside the wires insulation causing jerking and eventual stopping of motor. Motor resistance should read between 1 and 3 ohms. If this is the issue have the motor rebuilt.
Mar 14, 2014 | Quantum 614 HD Power Chair - Used Electric...
Hi I have a Jazzy 614 HD. I charge my chair with (new charger) and it turns off when fully charged and my Joy stick reads fully charged (New Joystick and new batteries) but within three to four hour
perhaps since your chair is over 2.5 years old you have underlaying problems such as motorheatup or excessive drag per a locked bearing or a bushingtrhat is out of lube.somebody needs to at everything that moves thathas to do withload carry,or powertrain.
Jan 12, 2013 | Pride Mobility Jazzy 614 HD Power...
Pride JET 3 Ultra power wheelchair. Problem: Batteries drain very fast after recommended charge. Things I have done: Replaced both batteries- twice; Replace On-board charger. Both items brand new. ...
check the motor brushes if they are 1/4 inch or less replace them. Next, after driving the chair for a while check the motor casing near the brake assemblies on the rear of each motor if the casing is hot then you have a sticking brake pad or pads and this can cause the excess battery drain. If you have sticking brake or brakes unfortunately the whole motor assembly will have to be changed Hope this helps
Jun 10, 2011 | Pride Used Mobility Jet 3 Power Wheel...
I have a Jazzy 1103 Ultra and the lights are all on like it should be but the chair will not move. I am in Mississippi visiting my daughter and would love someone to help me. Thanks!
It could be a few things.
It might be on freewheel. To solve this: 1. Turn the chair off. 2. Locate the freewheel lever just behind the drive wheel, and on top of the motor. 3. Push the lever inward to engage the motors. 4. Repeat steps 1 and 2 for the other side. 5. Turn the chair on and see if it works .
If not, it the circuit breaker might need to be reset because of heavy strain on the motors and batteries. To solve this: 1. Turn the chair off. 2. Find the circuit breaker on the front of the case, off to the right side (you will see a hole in the case) 3. Press the circuit breaker button. 4. Turn the chair on and see if it works.
if not, the battery may need to be disconnected and reconnected To do this 1. Turn the chair off 2. Release the friction lock lever under the seat. 3. Remove the seat. 4. Release the rear shroud fastener and the yellow fastener under the front shroud. 5. Remove the shroud. 6. Disconnect and reconnect the battery connector (the big plug) 7. Replace the shroud and seat. 8. Turn the chair on and see if it works.
If not, contact your provider.
Feb 23, 2011 | Pride Jazzy 1103 Ultra Indoor Power...
Batteries run low fast on jazzy jet 3, heard brakes might be failing or motor needs replaced after replacing batteries?
one battery was low,,,,not sure if anyting else is bad, used chair...by having only one battery low, it ran down the chair...
Mar 27, 2009 | Pride Mobility Products New Pride Mobility...
No drive,flashing green light
Are you sure the FREELEVER is in the right position ? , to test try to push the scooter ?
Battery Low ?
Mar 12, 2009 | Electric Strider Midi 4 Wheel Mobility...
Wheel chair will not stayed charged.
Something is discharging your battery. Possible the unit have ground fault that cause the battery lost its charge. Try to remove this ground fault & you will solve the unit problem.
Feb 19, 2009 | Jet 1HD Power Electric Wheelchair
Jet 1HD Power Electric Wheelchair Logo
304 people viewed this question
Top Jet Health & Beauty Experts
Marvin
Marvin
Vincent G
Vincent G
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
