Question about Apple iPhone 3G
Icons are too big and I cant scroll to see all icons
Posted by jbd2bad on
Anonymous
    President:
  • 239 Answers
Double tap the screen with 3 fingers and it will unzoom. Then to switch the feature off, go to settings, accessability and turn off zoom feature.
Hope this helps and if so please vote.
Thanks
Jim
Posted on Oct 09, 2010
virtualhost
    President:
  • 2,185 Answers
You need to tap three fingers on your iphone's screen at the same time. What happened was that you might unintentionally tapped three fingers in your iphone's screen when grabbing it from your pocket or bag.
Hope this helps.
Posted on Jun 03, 2010
How to reduce ddessktop icon size?
hey wassup
theres two ways you can go at this.
1. right click on an open area on ur desktop and just adjust the icons when u hover over the [view] option
2.make sure ur desktop is the only thing visible and give it one click on an open space just to make sure nothing is selected. then hit ctrl+&
at this point to test if it's working. hold ctrl then start to move your mousewheel on your mouse and the icons will start to all magically increase and decrease in size
now option #1 is a bit more easy and its static
while option#2 is a bit more dynamic and you can really make your icons really big or really small. it's up to you.
Nov 18, 2014 | Computers & Internet
Icons on windows desktop
You can resize the icons on your desktop as follows:
right click anywhere on the desktop and select view and then you will have the option to select different sizes for your icons.
Hope this helps.
May 06, 2014 | Computers & Internet
Text, Icons and Bars set at 500% cannot change
Hook up a mouse with a scroll wheel if you have one, hold down the ctrl key on your keyboard then scroll down on the mouse wheel. See if that works. If it's your desktop that is big as well, right click the desktop, click where it says screen resolution and change it to make it smaller. If that doesn't work let me know and we will try something else for you.
May 05, 2014 | Acer Aspire Computers & Internet
I accidently pressed the wrong language cant understand how to get it back to english! help me please
1. Switch on camera.
2. Press MODE button to access the Set Up menu.
3. Use Multi Selector button to select the spanner icon.
4.Menus will be displayed in Text or Icons.
4.1. If in Text just scroll down to Language and click OK then scroll toEnglish and click OK _done.
4.2. If menus are in Icons scroll down to a FLAG Icon and click OK then scroll to English and click OK.
May 21, 2011 | Nikon COOLPIX S200 Digital Camera
My screen of computer is so big the contents are enlarged my kid has pressed some buttons pls help
Hi nayyarshelly,
I like to help you regarding your concern having big Icons on your desktop, you mentioned that your kid accidentally pressed something on the machine that made everything big, See steps below to changes the Icons or your systems desktop settings.
  • First the system should be turned ON and logged in to Windows, I am assuming that you have Windows7 on your computer.
  • On the keyboard Hold down the CTRL button while holding down the CTRL key on the mouse scroll, scroll backwards this should make things smaller again.
  • If the screen on the Internet is also big do the same thing while your Internet Explorer is open this should change the size of the text / pictures anything on the Internet explorer.
  • But if the above does a different function from what you are experiencing then I believe that you are experiencing some changes in the resolution of the screen if everything is Enlarged.
  • Click on Start then on the search bar type in display, a list will show look for Display then click on it to open up the Display window then click on Adjust resolution.
  • The resolution on your screen depends on how big the LCD screen is
  • On the Resolution page you can pretty much check each resolution on the list that will be better to you, then click on Apply lower right then OK to apply settings on this page.
I hope that this will be of help regarding your concern.
Have a nice day,
mvincentc
Apr 24, 2011 | Computers & Internet
How do you change the language back to english on a ds my monkey family
1. turn off the DS
2. turn it back on.
3. select Petz icon
4. press the globe icon at the lower right corner.
5. scroll right or left till you see the word "English" in the sentence.
6. select (yes) by selecting the "O" in the big blue box.
7. select the little suitcase icon in upper right corner.
8. select the icon that looks like a gear or flower.
9. select the top icon (disk) at the left to save the new language setting.
10. then select yes by touching the "O" in the big blue box.
should be good now, took me like 30 min b4 realizing I probably can just reboot the game and hopefully it will ask me what language...after i realized it was in Danish...i was able to locate the word "language", which is "sprog" in Danish.
~Serena
Apr 11, 2011 | Buck Petz: Monkeyz House for DS
How do I fix the size of my icons and make the internet fit to size
How to resize Vista desktop icons
One of the complaints I hear about the Vista GUI is that "the icons are too big." Well, fixing that is a simple matter. Here's how:
Right click an empty space on the desktop.
Select View.
Click Classic Icons.
Another way is to use the scroll wheel on your mouse or trackball. With the cursor on the desktop, press and hold the CTRL key and scroll the wheel to make icons larger or smaller.
I hope someone having that problem will read this thread.
Cheers!
Jun 24, 2010 | Microsoft Windows Vista Home Basic Edition...
My blackberry 7520 is missing the wrench icon someone hit the hide button and I cant find it please help me
To show all hidden icons:
- Press the Function button (the button directly under * A).
- Click the Scroll Wheel.
- Click on Show All. All application icons will appear.
Oct 06, 2009 | RIM BlackBerry 7250
Need touch pad advice
probably need a driver or at least an updated driver.
Also go into the control panel and see if there is an icon for the touchpad... double-click on that icon and look for settings to enable the scroll pad.
Mar 07, 2009 | Dell Inspiron 6400 Notebook
Apple iPhone 3G Logo
139 people viewed this question
Top Apple Cell Phones Experts
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
B Louis
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
