No picture No audio
56'' or so projection HD TV. Worked fine for a year or so, then loud pop sound and now no picture or sound. When I turn it on, the red powerlight comes on and I hear it power up, but nothing on screen or out speakers.
Posted by fixya861 on
electroman
    Genius:
  • 1,039 Answers
Replace the lamp.
Posted on Nov 01, 2009
How to repair my Samsung TV? When the TV is turned on it powers on and off non stop until unplugged.
Hi, the motherboard could have been affected. Since you have ever replaced the power supply, its better you get a new motherboard.
Nov 16, 2015 | Samsung Televison & Video
Philips Magnavox 9P6031C103 projection tv quit working 2 years ago (before, the picture began to shink and expand until it finally quit completely with no audio nor video -- turned it on two years later to...
Based on what you described I would say your TV has the "shrinking and expanding" fault. Its a common problem on that model and the symptoms can range from the video shrinking and expanding or no video or no audio....You can read more about this fix on the site www.TvRepairKits.com
Jan 13, 2013 | Philips Magnavox 9P6034C 60" Rear...
I have a 52" rear projection vivitek dlp tv. Picture is fine, but it has a loud humming sound. Does anyone know what it is or how to fix it??
turn on video mode if loud humming still occurred replace filter capacitor on audio section from your tv ckt board.
Mar 31, 2010 | Vivitek V37655 56" DLP TV
Suddenly pic went out. Loud crackling and popping heard. Now, Blue indicator and red power light continually flashing. I think lamp. Unit 3 years old
the lamp has blown replace if got instruction book that came with tv shows you how if not got the lamp is behind cover on side or frount cover that comes off by undoing two black screws on back corners (each lower corner) anda sharp pull will remove cover
Dec 13, 2009 | JVC HD-56G786 56" Rear Projection HDTV
Loud Buzz
loud buzz is the color engine, turning the color wheel. Find instructions on how to take it out and clean it and that should fix that problem.
Jun 28, 2009 | Sharp 56DR650 56" Rear Projection HDTV
Loud popping on jvc av56wp74
if the noise is from inside the tv in the back,the high voltage transformer that feeds the anode for the rgb tubes,28000volts probably is arcing.
May 23, 2009 | JVC AV-56WP74 56" Rear Projection...
Sound won't turn down
Change out your audio cables ,if this does not work some where you are missing ground.or its not connected right.ThankYou for using FixYa. Have a Nice Day.
Feb 17, 2008 | Toshiba 51H83 51" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Lawrence Oravetz
