Question about RCA D52W23 52" HDTV CRT TV
Double vision on the 52 inch tv in red and the top sags down a couple of inches like a smiley face smile
    Genius:
  • RCA Master
  • 1,039 Answers
Resolder the connections on the high voltage transformer. There are 3 fuses mounted to the right of this transformer. They look like 3 brown boxes. Replace the center one if its open. ABOUT 1/2 AMP pc mount fuse pico fuse will do. Common failur eon this tv.
Posted on Nov 01, 2009
Testimonial: "I really appreciate this information.I will have my brother do this when he has a little time.we live in rural area noone to fix TV"
I have a Sharp 36F-630 36" TV. Recently, it started getting a "band" across the top of the screen. It gets smaller as the tv warms up. It used to go away completely. Now it goes from...
You have a swollen capacitors in the vertical section try to replace all the leaky capacitors, you will notice that there is a liquid leaking out in the buttom of the capacitor.It is like an oil spill.
Dec 06, 2010 | Sharp 36F-630 36" TV
Sony 52 inch, model number kp 53n74, stopped working
I have the same model Sony TV with a September 1999 manufacture date just did the same thing Friday! How are we suppose to find out what's wrong
Feb 22, 2010 | Sony Televison & Video
The upper burr stuck upside down!
Yes, this butter knife trick is the way that Capresso customer service recommends. Just to clarify the tip of the butter knife is the only portion inserted...DO NOT shove the entire blade into the grinder. Just the tip in the furthest to the right side of the "smiley face ****" that is on the top of the grinder without the clear plastic hopper. just imagine a birds eye view. Once you have the tip of the butter knife all the way to the right of the "smiley face ****" then just rotate counter-clockwise until it does not go any further. This should have dislodged the top part of the grinding cone and then simply pick it up with your fingers, flip 180 and put it in the correct way.
Jan 30, 2010 | Jura Capresso Infinity 565 / 560 Grinder
We have a 52 inch that all of a sudden began to have red and green colors and were overlayed like double vision. It is not a convergence problem - a friend tried to help us with that already. Everything...
need tyio repair the convergence circuit if the picture starts to look 3-D , you will need to google a place that sells the complete kit for that problem, Larry Dillon
Aug 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
52 inch has double vision like the red and gereen colorr are serperated.
the convergeance is off. some remotes allow you to tune this in the setup menu on your television. in most cases though this is something that has been caused by moving the television around or just plain ole time. if you cannot correct it using your remote and the normal menu on your tv then you will need to contact a repair technician in your area to schedule him/her to recalibrate your tv and repair the separating 3d looking issue that is common with convergeance.
Good Luck!
Ruben
Jul 20, 2009 | Philips Magnavox 9P6034C 60" Rear...
Colors have seperated on tv, and curve
You have a convergence problem.
Maybe need change the IC of convergence, or the power supply of these parts.
Bye.
Apr 04, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Double vision tv
MY TV WON'T COME ON? MY POWER SURGE WORKING IS WORKING.
Jun 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic PT -47WXC43G 42 inch TV
replace the convergence amp ICs both of them. They cost about 15.00 each
Mar 09, 2008 | Panasonic PT-53WX42 53" Rear Projection...
RCA D52W23 52" HDTV CRT TV Logo
193 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
