Have a 1998 wild wood travel trailer and need to do some electric work. Gas furnace went out and I want to install an electric heater where the furnace was and the wiring there does not show a ground wire and I can't find it. Do you have a electrical schematic for this rv trailer
Hello. I can help you. Your gas furnace only needed a small amount of electrical power to operate. The electric heater on the other hand will need a lot more power and most likely will need 220 volts as opposed to 110 volts for the gas furnace. Therefore, a new line to feed your electric heater, sized appropriately will have to be run from the electrical panel to the electric heater. I recommend that you have a pro do this wiring job for you as there is no room for error. Good luck with it.
