Question about Apacer Memory Apacer Audio Steno AU822 MP3 Player
My mp3 doesn't charge
I plugged my mp3 to pc and left it to charge all night. It started to charge. But in the morning when I unplugged it, it hadn't charge almost at all. I could listen to one song (4 minutes) and then it turned off and I couldn't turn it on anymore. How can I get it to charge properly ?
Posted by Laura Konnula on
Tom Chichester
    Top Expert:
  • Apacer Memory Master
  • 55,635 Answers
The battery may be depleted and unable to recharge completely.
Posted on Mar 05, 2018
5 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: my philips gogear (6 GB) MP3 player is really messed up and i need help
Here's what happened: When you first synced your GoGear to Windows Media Player, you may have set up the automatic sync option. When this option is selected, Windows Media Player will add EVERY song, picture, etc from your Library on your computer to the GoGear. Now, every time you sync you device, it adds every new file from your computer into the GoGear automatically. It will even delete songs from your GoGear that were on there before.
Go into Windows Media Player 11 with your GoGear connected to the computer (it will automatically sync and add new files one last time), move the mouse cursor over to the sync tab; a small black arrow will appear under the word "Sync"; click on the small black arrow and a dropdown menu will appear; select "Portable media device" from the dropdown menu, and another dropdown menu will appear; select "Set Up sync"; a window will appear with some information on your device - uncheck the box that says "Sync this device automatically"; click Finish; This will eliminate the problem of Windows always adding songs/files you don't want into your player.
-Tha Mp3 Doctor
Posted on Feb 11, 2008
Anonymous
SOURCE: Won't delete songs
EEK i know what this is , the memory cells or NAND/Flash storage on the mp3 is dying as you cannot delete it , you can try to add an sd/mmc/xd card if your mp3 supports to add and delete songs as it wont be affected it but it wont cure the fact that you cant delete it .
Alternatively you can update the mp3 player firmware by downloading it from the web or you can try to return it under warrently (number in support manual)
As a last resort you can connect it to the pc right click it and press format this will erase all data /everything on your mp3.
Posted on Oct 14, 2008
Anonymous
  • 3 Answers
SOURCE: It will not play songs anymore.
go to music and press play all
Posted on Jan 29, 2009
shadow83
shadow83
  • 496 Answers
SOURCE: Deleting songs off mp3
try using windows media player to navigate thru the file on you mp3 player and delete the ones you dont like on it then use the media player again to sync the new ones onto it
Posted on Sep 24, 2009
Ed Mac
  • 731 Answers
SOURCE: I put songs on the
Does it stop at the same song each time?
If so that file is corrupt. Delete it and it should work fine
Posted on Jan 21, 2011
What can i do when water is inside my mp3 player, then i lost it for a month. when i found it , i immidiaetly plugged it into my computer, it started working. i let it charge. when i took it out, it...
Good morning, afternoon, evening or night; whatever time of day you are viewing this post. Thank you for choosing FixYa to assist you with your problem. Your MP3 Player has been exposed to water, then it gets lost, you find it and immediately plug it into your computer for it to charge and start working again, then it shuts off after you unplug it from the PC. I don't know if you know this or ever read it in user manuals, but they tell you not to expose your electronic device to liquid substances. This can cause product failure as well as harm to yourself or others. I'm surprised it's still working when you plugged it into the computer. I had a flash drive that went through the same experience as your MP3 player: got lost and was exposed to rainwater, then was found later and started to work again once it was plugged into the computer. Later on though, the computer failed to recognize it and it eventually stopped working. I'm thinking the situation with your MP3 player is that the battery or a driver controlling battery functioning, is defective due to water exposure. The driver that controls the PC launch up, may not have been exposed to it as much. You could try opening your MP3 player (if it can be opened) and try to drain all the water out of it, then put it back together and try to turn it on again. If that doesn't work, plug your device into the computer and go to the device manager on your PC. If your computer recognizes the device, go to its properties and click the driver tab. Click "Update Driver" to see if a driver update is needed. If the driver is up-to-date, try uninstalling the driver, then reinstalling it again. If your device is not working properly after this. Then the battery, driver or other electronic circuitry inside of your MP3 player is defective. You can try to replace the battery, if it can be, to see if that makes the difference, but I'm pretty sure your MP3 player is defective now. I'm sorry for the inconvenience, but thanks for choosing FixYa to assist you with your problem. Have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
May 23, 2011 | Audio Players & Recorders
Sansa clip won't charge fully
If you have a phone charger with the same connector, plug in you Clip and leave it overnight. This will fully charge the battery. There is not enough power from the USB port.
Aug 08, 2009 | SanDisk Sansa Clip MP3 Player
New GoGear Vibe will not turn on after first charge!
This is not a solution to fixing the mp3 player, but I no longer need assistance, I returned the product for a refund.
Jun 04, 2009 | Philips GOGEAR SA6045 MP3 Player
My Creative Zen Mozaic 4GB won't turn on
Use the reset button located on the left side. Worked for me!
Feb 05, 2009 | Creative Labs Creative Technology Zen MP3...
Zen Vplus 4G problem
try leaving it connected to the usb and pressing the reset at the same time
Sep 02, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen VPlus 4G
press the reset button while its connected to the usb-worked for me-not sure why but it did-
Sansa Fuze not working anymore
My friend give me a sansa mp3 player BB0703UBB. When i charge it in my PC and i forgot to unplug sansa mp3 player BB0703UBB after half hour i plug it. But the power is not working. i cannot open and play it anymore. I try to insert it on my PC but then it says unknown device. HELP!
Jul 17, 2008 | Audio Players & Recorders
Creative Labs Vision M Mp3 Player won't charge all the way
i can not install or put music on and it has the words shut down and it has not shut down it been like that for one day
May 04, 2008 | Creative Labs ZEN Vision:M Digital Media...
BIG problem. PLZ help!!! :(
The Samsung YP-F1 has a reset button located under the black Samsung cover plate. It can be gently removed via a finger nail or mini flat blade screwdriver. Once plate is removed a hole labeled reset will be seen. Use something like a paper clip and press in. MP3 will power down/reset. MP3 data is also retained after reset.
Apr 03, 2007 | Samsung Yepp YP-F1X MP3 Player
Apacer Memory Apacer Audio Steno AU822  MP3 Player Logo
Top Apacer Memory Audio Players & Recorders Experts
vinayghl
Tom Chichester
Bill Boyd
Are you an Apacer Memory Audio Player and Recorder Expert? Answer questions, earn points and help others
