Computers & Internet Logo
Posted on Nov 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Everytime I restart my computer I have to run the connection diagnostics to get access to the internet. I am running windows xp with an AT&T gateway 2 router.
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Nov 01, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557154
Points
31058
Cut power to the router.
Reconnect it, and let it start-up, for 2 minutes.
Restart your computer.
Click Start
Click Run
Type CMD and press ENTER.
Type IPCONFIG /ALL and press ENTER.
Record the information, e.g., 'IPCONFIG /ALL > temp.txt'
Type IPCONFIG /RENEW and press ENTER.
Better? Worse? Same?
Driverboost free version
Driverboost is known to cause damage and problems. In the future I recommend avoiding any programs that claim to update your drivers, boost your registry, or speed up your computer - they are all JUNK. and bad for your computer!
tip
Cannot access internet!!!!!
Using Windows Operating Systems:
Windows XP:
1.Powercycle equipment (Unplug power wait 15 seconds then plug back in)
2.Go to Start/Run/Type ncpa.cpl then hit ok.
3.Double Click Wireless Connection (Router Connection) Hit Properties.
4.Click on tcp/ip then hit Properties
5.Ensure Obtain ipaddress automatically is checked as well as Obtain a DNS server automatically is checked.
6.Restart Computer, If still unable to access internet check you Firewall:
Start/Control Panel/Windows Firewall/Change Windows Firewall Settings/Turn Off not recommended.
7.Last Go to Start/Run/CMD/Hit ok
A.Type netsh int ip reset reset.log Press Enter after every Command
B.Type netsh int ip delete arpcache
C.Type netsh winsock reset
D.Type ipconfig /flushdns
8.Restart Computer
9.If still having issues check for viruses or malware in your computer.
10..Refer to your manufacture.
Windows Vista/7:
2.Go to Start/Search Bar/Type ncpa.cpl then hit Enter.
3.Right Click on your connection usually (Wireless) then click Properties.
4.Uncheck Internet Protocol Version 6 IPV6
5.Click on Internet Protocol Version 4 IPV4 Then hit Properties (Do not uncheck IPV4)
6.Ensure Obtain ipaddress automatically is checked as well as Obtain a DNS server automatically is checked.
7.Restart Computer, If still unable to access internet check you Firewall:
A.Start/Control Panel/Security/Allow Program Through Windows Firewall/General Tab/Turn Off.
8.7.Last Go to Start/All Programs/Accessories/Right Click on Command Prompt then hit Run as administrator and hit continue.
10.Refer to your manufacture.
on Jan 11, 2011 • Computers & Internet
Windows xp would not update
Access the KB971058 article via Internet Explorer (only) & run the Fix It 50202 in DEFAULT and AGGRESSIVE modes.
http://answers.microsoft.com/en-us/windows/forum/windows_xp-windows_update/windows-auto-updates-wont-turn-on/c9d6b1be-a36c-e011-8dfc-68b599b31bf5
A general fix, *IF* there's no malware issue, would be to reset the updating components: How do I reset Windows Update components ?
<<http://support.microsoft.com/kb/971058>>
Run Microsoft Fix it 50202.msi, and first choose the Default mode.
Restart.
See if the system can update now. If no joy, run it again with the system connected to the internet, in the Aggressive mode.
Restart.
or
http://answers.microsoft.com/en-us/windows/forum/windows_other-windows_update/windows-update-hangs-when-searching-for-current/f680b16d-1dee-4054-8d44-a05ace0c0fff
3helpful
3answers
Slow internet connection
A slow Internet connection could be caused by any number of reasons. It may be connection or traffic problem.To increase your internet speed use the following tips given below:
1.clear cookies from your browser
2.Delete unwanted files
3.PC Optimization:
It is important to clean your PC regularly. It means a normal maintenance tasks such as, cleaning the disks, registry repairs and Disk Derangement.
4.If you are using a DSL connection over your landline, make sure that you have high-quality filters in place to get optimum signal speed.
5.Upgrade your modem.
6. Use Updated browser.
7.Consult with your Internet service provider to ensure that your modem is configured correctly.
8.Replace your telephone modem with a fast-access connection such as wave, ISDN, DSL, satellite, a cable modem.
9.Tweak our router settings
10.Install Antivirus Software.
11.Reduce our bandwidth overhead
After, completing this steps, you can check our internet speed whether increase or not using this site ScanMySpeed.com
Internet explorer stopped working
Diagnose Connection Problems With Internet Explorer
Internet connection and network errors can be frustrating and confusing to a casual computer user.
However, Internet Explorer provides a diagnostics tool to help identify and even repair the most common network issues.
This tool is simple to use, organized in steps, and can help get a computer back up and running quickly.
Open Internet Explorer and click on the "Tools" button in the control bar at the top of the window. From the "Tools" menu, select "Diagnose Connection Problems."
A window will appear, displaying the start page of the diagnostics tool.
Follow the instructions to determine the cause of the connection error.
The diagnostics tool will ask a series of multiple-choice questions about the connection problem you are experiencing.
Close all programs and restart the computer.
If you continue to receive an error when attempting to connect to the Internet, check that all cables and power-supply cords for the computer, modem and/or router are properly connected. Then, run the diagnostic tool again.
Call your Internet service provider's technical support phone number if you cannot resolve the error with the diagnostics tool.
The Internet Explorer diagnostics tool cannot repair or reset malfunctioning or failing hardware like modems and routers.
windowsxp using networking expert russel diagnostics mspx
http://www.microsoft.com/windowsxp/using/networking/expert/russel_diagnostics.mspx
Support for Windows Internet Explorer 6, 7, 8, and 9
http://support.microsoft.com/ph/13418 - tab0
Internet crashing
If your Internet Explorer keeps randomly crashing (closing by itself), there may be an add-on or temporary page disrupting the connection.
Every time you browse the web, Internet Explorer keeps track of the websites you visit.
It keeps these pages, along with cookie trackers, in the "Temporary Browsing History" folder. Some websites cause Internet Explorer to crash.
Open the Internet Explorer browser. Go to "Tools > Delete Browsing History."
Hit "Delete All."
Check off the box that says "Also delete files and settings stored by add-ons."
Hit "OK."
Close and reopen the browser.
Disable Add-Ons
Go to "Start > Search."
Type "Internet Explorer" and hit "Enter."
The computer will search for any files with this label.
Double-click on the file that says "Internet Explorer (No Add-Ons)."
This will allow you to browse in IE without any additional plug-ins or add-ons that might be causing the browser to crash.
Reset Internet Explorer
Open the IE browser.
Go to "Tools > Internet Options."
Hit "Advanced." Click on "Reset" and then hit "Enter."
You might have to many programs trying to or accessing your computer or the internet at the same time or a virus
Scroll to bottom toolbar (bottom of screen) right click select task manager applications and processes to see you what's running and ticking over
if you see anything you don't need running select end now and you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be jamming up your computer
also under processes see what is ticking over in the background again if you see something you
don't need to be running select end now and users you will see who is using your computer
http://100-downloads.com/download.php?p=615
windows xp microsoft security essentials
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
3helpful
Lap Top access - unable to access internet on lap top
1.Powercycle equipment (Unplug and plug back in)Wait 15 seconds then plug back in.
2.Check connections the Ethernet cord from modem should be plugged into back of router into internet port.
3.If modem runs off signal from a local tower and there is not sufficient signal on the modem you will need to contact your ISP ( Internet Service Provider) to check for outages if not skip to step 4.
4.Open your network connections window.
A.Windows XP:Start/Run/Type ncpa.cpl this will bring you to network connections.
B.Windows vista/7 Start/Search bar Type ncpa.cpl
5.Windows XP:Right click on Local Area Connection and click properties,
A.Click Internet Protocol and hit properties ensure Obtain ipaddress automatically and Obtain DNS service automatically is checked if not check both and close window.
B.Windows Vista/7 Right click Local Area Connection and click Properties, Uncheck Internet Protocol Version 6 and click on Internet Protocol Version 4 and hit Properties Ensure Obtain ipaddress automatically is checked as well as DNS server.
6.You will need to manually renew ipaddress if this does not work
A. Windows XP:Start/Run/Type CMD and hit enter,
B.Type ipconfig /release
Then type ipconfig /renew then restart computer
A.Windows Vista/7 Start/All Programs/Accessories/Right click Command Prompt and hit run as administrator.
Then type ipconfig /renew restart your computer
7. If this does not help run an Antivirus. Hope this helps Happy Thanksgiving
1helpful
2answers
How to pass genuine window validation
Please follow this simple troubleshooting procedure, courtesy of MS MVP
Carey Frisch:
1. Download and install the WGA Diagnostic Tool
http://go.microsoft.com/fwlink/?linkid=56062
2. After running the WGA Diagnostic Tool, click on the "Windows" tab and
then click on "Copy to Clipboard".
3. Next, visit the following website and create a post in the "WGA
Validation Problems" forum and paste the results of the WGA Diagnostic Data
in a detailed post:
http://forums.microsoft.com/Genuine/...aspx?SiteID=25
4. A WGA troubleshooting specialist will analyze the data and recommend an
appropriate solution.
In the end you may end up having to buy a genuine copy of Windows XP.
1helpful
My windows xp has no internet connection. i install windows vista and it has internet connection and i install again windows xp and it has no internet connection w is the problem?
There are some windows will not run automatically the internet connection. You should install the motherboard driver so that the network or internet connection will functioning. After installing it will required you to restart your computer system to take effect.
I have a new zyxel router connected to my computer by ethernet cable. I have windows xp. Everytime i start up I have to disable the wireless connection switch off the computer then restart it and enable...
Why do you require a wireless connection on the computer, when it is already connected to the router through ethernet cable? Disable the wireless connection permanently & try.
Top 2wire Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
