Sony TC-WR565RM Single Cassette Deck Logo
Posted on Nov 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the noise ratio of te WR565rm tape deck
electroman
Level 3:
Genius:
  • Sony Master 1,039 Answers
  • Posted on Nov 01, 2009
electroman
Sony Master
Level 3:
Genius:
Answers
1039
Questions
Helped
305095
Points
2353
Why would you care. Cassette tape decks all have poor s/n ratios. Dolby was somewhat helpful but the tape moves accross the head too slow. Since the advent of digital audio all of the current cassette decks are truely junk.
2answers
Manual JVC TD-W207
Type: auto reverse, double compact cassette deck
Track System: 4-track, 2-channel stereo
Tape Speed: 4.8 cm/s
Heads: 1 x record/playback, 1 x playback, 1 x erase
Motor: 1 x capstan, 1 x reel, 1 x mechanism
Tape Type: type I, CrO2, Metal
Noise Reduction: B, C
Headroom Extension: HX Pro
Frequency Response: 20Hz to 17kHz (Metal tape)
Signal to Noise Ratio: 73dB (dolby C)
Wow and Flutter: 0.08%
Total Harmonic Distortion: 0.8%
Input: 80mV (line)
Output: 300V (line)
Dimensions: 435 x 133 x 328mm
Weight: 4.9kg
How do I set up my jvc_td309 double cassette deck for recording on cassette tapes? Also what settings?
Adjust recording bias, if one, for the kind of tape you are using and you are good to go. For best performance use the brand of tape that was used to set up the machine when made.
If you have a fine tuning control for the bias, use it per instructions for best frequency response and s/n ratio.
My Sony TC WR 535 wont open doors, one cassette in deck B,lights blinked in display panel then unit shut down, not been able to turn it on since
Remove the cover after unplugging AC. Look for a plastic stop that keeps the eject button from going in farther. Move the plastic stop peice downward and the buttom will then move in all the way and tape will eject. On mine the plastic piece is white and rotates down.
Ik heb een cassette recorder de TC-RX311 met serienummer 5502612 en wil het bandje niet meer laten draaien. Hoe en wat ?
Kan slijtage aan of een gebroken/gebarsten tandwieltje zijn. In beide gevallen moeilijk te herstellen. Bij goedkope decks kan het ook een gebroken aandrijfriempje zijn.
Cannot get the tapes out of the deck
either your tapes have been chewed or you have no power going to you open/close button unscrew screws on side make sure its not plugged in and take off lid then you will be able to get your tapes out you should have a manual over ride button on the inside.
Sony TC WR565 dual tape deck. Both doors will not
you can not fix it without tearing it apart. if you do take it apart, try to get the front panel off. Hit the eject button and look for a lever that is stuck.
2helpful
SONY TC-WR550z dual tape deck eats tape and doors won't open I hadn't used this unit in 5 year (it's 13 or 14 years old), and before it worked fine. I went to use it again last month (MJ "Thriller" tape!)...
I don't know anything about the "eats tapes". You can take out your tape fairly easily thought. All you need to do is
unscrew screws on the left and right side of unit
remove the cover
use a flat head screw driver to gently push down on a white lever on the side of the drive mechanism while pushing the eject button
Replacing bands
Since the belts control the timing of the mechanism, I would not recommend this as a home repair. While relatively simple compared to some, this still is a delicate repair that can easily go wrong. Please bring this unit to an audio repair shop. Expect a parts cost in the $15-$20 range. There are 3 belts inside.
Dan
Squeeky tape deck
With the top off get hold of a flexable tube. One of those drinking straws that has a bend will do and place one end in your ear and search for the noise (like a stepescope). You might see what's causing it then.
I suspect that grease would not cure it. But try Silcone (from Maplin's (UK) or other type store, if you think it might need grease.
2helpful
Sony Stereo Cassette Deck TC-WR550Z
Drives belt has become too slack to drive mechanism properly or the drive motor is bad. Have unit serviced for new belt(s)
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
