Samsung SGH-D900 Cellular Phone Logo
Question about Samsung SGH-D900 Cellular Phone
Time reset: from daylight saving to standard time Have Samsung set to EST. wnat to reset to AST time zone. Found nothing in manual or options
Posted by algerbrook on
  • algerbrook Nov 01, 2009
    Have fixed problem. Further service not required.
    Thank you.
3 Related Answers
Anonymous
SOURCE: update time
the reset code didn't work
Posted on Mar 11, 2008
Jon Schlaman
SOURCE: Samsung Impression :Daylight savings time moved all the appts
This is the second Samsung phone I have had that did this. The A707-Sync had the same problem. I called Samsung tech support and they told me to disable the auto-update feature for daylight savings. Not a great solution, but the only one I got.
Posted on Mar 17, 2010
Anonymous
  • 110 Answers
SOURCE: with daylight saving time, my
Go into the settings menu and adjust the time under "Date and time" .
Posted on Mar 14, 2011
1helpful
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
1helpful
2answers
How do I change from Fahrenheit to celcius? Model # 00621cadia2
You can download the manual here http://www.acurite.com/kbase/00621_Weather_Station.html
Set the Time, Date & Units Press the "SET" button, located on the back of the display unit, to enter SET MODE. Once in set mode, the preference you are currently setting will blink on the display.
To adjust the currently selected (flashing) item, press and release the "up" or "down" buttons (press and HOLD to fast adjust).
To save your adjustments, press and release the "SET" button again to adjust the next preference. The preference set order is as follows:
TIME ZONE ( PST MST CST EST AST HAST AKST) DST (Daylight Saving Time ON or OFF)*
CLOCK HOUR
CLOCK MINUTE
CALENDAR MONTH
CALENDAR DATE
CALENDAR YEAR
TEMPERATURE SCALE ( ?F or ?C) BAROMETRIC PRESSURE SCALE (inHg or hPa)
*If you live in an area that observes DST, DST should be set to ON, even if it is not currently Daylight Saving Time.
You will automatically exit SET MODE if no buttons are pressed for 30 seconds. Enter setup mode at any time by pressing the "SET" button.
Why is the time on my weather station always 3 hours behind
You need to set up the correct time zone offset. For example, CST is -6; EST is -5. If daylight savings is active, time will be: CDT = -5; EDT = -4.
CST = Central Standard Time
EST = Eastern Standard Time
CDT = Central Daylight Time
and so on.
The Official NIST US Time
Synergy global supply model 9105 how to set
http://www.synergythesource.com/doc/alarm-clock-setup-910500.pdf
Quick Setup
Model 9105
Alarm Clock Radio
1) Plug clock in before making any adjustments.
2) If using on East Coast- Do nothing! Time and date are set to EST- Daylight Savings time is 'On". Clock is ready to use.
3) If using in time zones other than EST. Hold the clock with LCD facing you. Lean clock back and find small button on bottom right marked P-M-C-E. Hold for 2+ sec. LCD will blink the time zone. Press button again until LCD blinks the correct time zone, CST, MNT, PACIFIC.
4) Daylight Savings time- Default is always on. If you are in a zone that does not recognize daylight savings time. Hold the clock facing you, lean clock back and on bottom left is a small button marked D. Hold 2+ seconds and the LCD will blink ON. Press again and LCD will blink OFF. Daylight savings time is now OFF.
5) If power goes out, clock will retain time and alarm will sound if in the ON position.
6) Replace batteries once every year...!
7) If clock looses time or date:
a. Hold Volume +, and Tuner + at same time for 3 seconds
b. Clock face will blink year
c. Turn outer ring of alarm to set Year
d. Press Tuner + once, turn outer ring to set Month
e. Press Tuner + once, set Day
f. Press Tuner +, set Hour
g. Press Tuner +, set Min.
h. Press Tuner + to save all settings.
You must go through all set points to have them remain in memory. (have to run thru all a - h, can't set just Day or Hour/Min, etc. without starting with Year)
Any questions please call:
Synergy Global Supply
804 435-7520
8:00am-4:00pm EST
3helpful
2answers
How to set the current time.time did not change when we turn the clock back one hour.
either your 1440 was never set to include daylight saving time or the unit was reset at some point.
the time is automatically set once you choose your time zone and if you observe daylight saving time, you must check that box..
go to the main menu, then system option and click on the time zone tab, then select your time zone and check off the little box for daylight saving time.
bill
How do I set the time on my Pioneer RT500?
Hi!
Please follow the instructions given below... =)
Setting the clock
The clock is set to the correct time automatically, but it
can also be set manually. The clock can be set for
daylight saving time and time zone.
Preparation:
• Turn ON the TV and set it to the video input mode.
• Select “CLOCK” from “SYSTEM SETUP”. For the
procedure, see steps 1 to 3 in “Using the SETUP
MENU”
1 Press SETUP while the DVD and video tape is
stopped.
The SETUP MENU screen will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
SETUP MENU
ENTER/
SELECT ENTER RETURN BACK SETUP END
SELECT
2 Press  or  to select the desired menu and
press ENTER.
The submenu screen of the selected menu will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
LANGUAGE
PARENTAL
CLOCK
DISC SETUP
OTHER
SETUP MENU
3 Press  or  to select the desired submenu and
press ENTER.
The screen for the selected submenu will appear.
CLOCK (manually)
You can manually set the date, year and present time
with the remote control.
Ex.: Setting the clock to “10:20AM” October, 30th, 2004.
1 Select “CLOCK” and press ENTER.
01/01/04 12:00AM
2 Select the desired items using  or  (month,
date, year, hour, minute and AM/PM) then press
ENTER.
3 Press  or  to set the value of the selected
item.
• For the minutes, press  or  once to set the time
minute by minute, or hold down either of buttons
for several seconds to set the time in 10-minute
intervals.
10/30/04 10:200AM
4 Repeat steps 2 and 3 to set the date, year and
present time, and press ENTER. The SETUP MENU
will close.
This completes clock time setting.
AUTO CLOCK
You can automatically set the clock by turning “ON” the
AUTO CLOCK function.
When you want to set the auto clock function to “OFF”,
select “AUTO CLOCK”, press ENTER and select “OFF”
from the list.
Auto clock setting
Preparation:
You must connect the antenna or cable before connecting
the AC cord to the power source.
Wait 30 minutes with the power turned off, after the
antenna or cable is connected, for the auto clock
feature to activate.
After the clock is set automatically, you may have to set
the time zone and daylight saving time. (See page 26.)
Press STANDBY/ON to turn on the DVD/VCR after the
auto clock operation completed.
• When shipped from the factory, the “AUTO CLOCK”
option is set to “ON” position.
• If you turn the DVD/VCR on during auto clock
setting, the clock is not set.
• After a power failure or disconnection of the power
plug, the clock setting will be lost. In this case, wait
30 minutes before turning the DVD/VCR on.
• With cable box connection, if the auto clock setting
is unsuccessful, select the PBS channel carrying
the XDS information, then turn the DVD/VCR off.
After 30 minutes, turn the DVD/VCR on.
• If the clock is not set automatically, set the clock
manually.
STANDARD TIME (Time zone)
In the rare event that you live within the broadcast range
of two stations in two different time zones, the DVD/VCR
may recognize the wrong station for the auto clock set.
To correct the situation:
Select “STANDARD TIME” and select the time zone from
the list below.
Selectable time zones and correction times
ATLANTIC: GMT – 4 hours
(GMT: Greenwich Mean Time)
EASTERN: GMT – 5 hours
CENTRAL: GMT – 6 hours
MOUNTAIN: GMT – 7 hours
PACIFIC: GMT – 8 hours
ALASKA: GMT – 9 hours
HAWAII: GMT – 10 hours
AUTOMATIC: AUTO SET
Note
• When shipped from the factory, the “TIME ZONE” is
set to “AUTOMATIC”.
• After making the auto clock setting, in some cases
the clock may display another time zone. You can
correct the clock by selecting your time zone
setting above.
• When the clock is not set or you set the clock
manually, the time zone setting is not available.
DAYLIGHT SAVING TIME
You can set the clock to daylight saving time automatically
or manually.
To select daylight saving time, select “DAYLIGHT
SAVING TIME” and select “ON”, while to cancel the
daylight saving time, select “OFF”.
ON: For manual setting (forward 1 hour)
OFF: For manual setting (back 1 hour)
AUTOMATIC: For automatic setting (read XDS in
the signal)
Note
• When you want to set daylight saving time, on the
first Sunday in April you set it to “ON”, and on the
last Sunday in October you set it to “OFF”.
• When shipped from the factory, the “DAYLIGHT
SAVING TIME” option is set to “AUTOMATIC”.
• When the clock is not set, the daylight saving time
• When there is no daylight saving time in your area,
always select “OFF”.
Change the time on the magellan roadmate 1212?
I was in same situation with a magellan roadmate 1212. From what I can tell, the "daylight savings" is not what many of us may be accustomed to... that is, that it means that the location you are at follows daylight savings as happens with Windows or many other devices.
I bet those in Arizona never had a problem becuase they don't follow time zone... let me explain....
The daylight savings seems to state "are we currently under daylight savings time?" if we say yes (as you would normally state in your Windows computer setting (that would determine when daylight starts and stops and adjust pc time accordingly), the magellan 1212 instead will "ADD" one hour to the time stated by the Satellites regardless on whether it is summer ... or not.
So, if you happen to live in a time zone that follows "daylight savings" and you currently are under "daylight savings" time, then set it so in the "time zone".
So, there are two things you have to do:
/menu/user options/system settings/time zone/
1)Set your time zone
2)If currently under Set/unset the daylight savings set button to yes and manually move to no when not on DLS.
The explanation I found in MagellanGPS website is below, but never mentions what is the meaning (I should say effect) of the "daylight savings" button checkmark.
Magellan GPS receivers are not able to set the Time manually. In order to have the correct time set on your Magellan GPS receiver, you must set the proper time zone you are located in (ie Pacific, Central or Eastern). Once the time zone is set the exact hour and minute will display as information is received from the satellites. The following information will assist you on setting the time zone on your Magellan GPS. For Outdoor Triton series 200, 300, 400, 500, 1500 and 2000
  1. From the map screen press Menu and select View
  2. Select profiles and press Enter
  3. Select hiking and press Enter
  4. Press the Page/Go To key once and scroll down to select time zone
  5. Press Enter to select your time zone and Enter again to confirm.
  6. Press ESC repeatedly until you return to the map screen.
Note: Make sure Daylight Savings is adjusted accordingly. For Vehicle Navigation series Maestro and RoadMate 1200-1430
  1. From the map screen select Menu
  2. Select User Options
  3. Select System Settings
  4. Select Time Zone
Disable Calendar
The Settings menu provides you with various setting
options to customise the phone to your preferences
and needs. You can also reset the settings to their
default values.
To access this menu, press <Menu> in Idle mode and
select Settings.
Time and date (Menu 9.1)
Use this menu to set the current time and date on
your phone.
Home zone: set the home time zone. Select the
city that corresponds to your home zone. To set
daylight saving time, select Set daylight saving
time
Time: enter the current time.
AM/PM: select AM or PM in 12-hour time format.
Time format: select the time format.
Date: enter the current date.
Date format: select the date format.
Auto update: activate the auto time update
feature. Your phone will read the MCC (Mobile
Country Code) from the network and automatically
update the current time for the country that you
are in when you travel abroad.
2helpful
3answers
Turning daylight saving time OFF
If DST is *already* set to "on" when you reset the time zone to Z-07 (Hawaii), my very recent experience is that the time *still gets adjusted back* by one hour.  Now that daylight savings time is over (at least according to the clock's pre-programmed and outdated schedule) I'm hoping that setting the time zone to Z-07 (Hawaii) will completely cancel the automatic time changes from now on.  Otherwise, I need to purchase another clock, and it won't be a Timex.
Top Samsung Cell Phones Experts
Robert
Steve
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
