Ambir Technology Avision 220 Pass-Through Scanner Logo
Posted on Nov 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Once i powered the avision 220 on, The moniter shows E and 7
Once i powered the avision 220 on, the panel show number 7 and the letter E and repeat this
Scan Aid
Level 2:
Novelist:
  • Expert 104 Answers
  • Posted on Aug 01, 2010
Scan Aid
Expert
Level 2:
Novelist:
Answers
104
Questions
Helped
127299
Points
181
When you first turn the scanner on, the READY light will blink, indicating that the diagnostics are in progress. Observe
the front panel Error LED (Red) closely. In a short time, the Error LED indicates the results of the offline diagnostics as
explained below.
Ready LED(Green) is off and Error LED(Red) indicates 7, the error indication is"Face down light check failure".
Followings are the solution for the above problem:
1. CCFL is on? Yes. CCD error, Optical assembly is to be replaced.
2. CCFL is on? No. Inverter error. Lamp inverter circuit is to be replaced.
3. CCFL is on? Yes. Issue resolved.
4. If the CCFL is still off, then CCFL is to be replaced.
Hope the above information is helpful.
Please revert if you have any doubt.
Thank you for contacting FixYa.
Regards,
TechSatya
Avision AD8150NP Document Scanner. We installed the driver and software and it gives us error 219 even though we tried to delete everything and reinstall.
Question edited for a lot more clarity and toss in some CAPS.
Link to the manual and maker support. You only get Support on the website if you enter the serial number.
AD8150 - Avision EN
avision.com https://www.avision.com > blog > document-tag
Why Avision · Corporate Profile · News · CSR · Scanner · Document Scanner ... Follow Us. Facebook-f Youtube. Copyright © 2023 Avision EN ' Powered by Avision ...
Avision AD8150NP Document Scanner User Guide
device.report https://device.report > Avision > AD8150NP
Avision AD8150NP Document Scanner User Guide · What's in the box · Install the scanner · Connect to Power · Install the Scanner Driver first and then the Button ...
2answers
I have a Westinghouse stove I need to find the age please.
The 4 th and 5 th numbers on the serial number show the Year . You can fine this google your stove and how to age
1helpful
2answers
My 2013 Patriot 2.0 won't start & battery, starter & alternator are good.
i would avise having the diagnostic equipment connected whilst driving car as this is an intermitent fault, this would need to be done by a qualified mechanic , and will show what is causing the problem if the OBD show everything is ok
2answers
How to unlock keyboard?
press numlock button once
Keyboard typing multiple letters/ numbers when pressing certain keys.
Keyboards on Windows computers can repeat letters when key press sensitivity is too high. This problem can be rectified by adjusting your keyboard's repeat frequency. Once this is lowered, key presses will occur slower and you will not have the letters repeated instantly.
Click"Start," then "Control Panel." Click "Hardware and Sound," followed by "Keyboard." Move the "Repeat delay" slider further to the left below the "Character repeat" option. The further left the slider moves, the longer the delay will be before a character repeats.
2helpful
The check engine lite won't go out after removing the power comander module. 2005 dyna wide glide
Chances are the PC created a trouble code that has not been cleared.
Use your speedo to check for codes.
1. With the bike off, push and hold in your odometer reset button.
2. with the button pressed, turn the ignition on, make sure your run/stop switch is on.
3. your speedo will do a sweep and when it comes back to 0, let your finger off. You should see a variety of letters, PSS ect. if you push the button briefly you can toggle between letters, you need to check every letter. So when the letter is blinking, press and hold the button untill the screen changes. Codes will show up as P0112 or B1110 ect. keep pushing the button untill you have all the codes. You will know when your done with the letter because it will show a part number, Example, P/N 19999-03 ect. Once you go thru every letter like this, writing down the codes, you can look them up online as follows: Harley DTC P0099 ect.
4. If no codes are present, it will go staright to the P/N. and you can click out of that to the next letter.
5.To clear the codes at this point, while you are looking for codes under the different letters, Simply press and hold the button, once it shows you the code.
So show the code, press and hold button till cleared, then press and relese button quickly to move on to the next number.
If after that, you turn the ignition off, then back on like normal, and the light should come back on shortly, but, once you start your engine the light should be off.
Need to record phone numbers on speed dial - have lost the owners manuel - 4 line phone
Storing a Name and Number in Memory
1. Press the STORE button on the handset, ENTER NUMBER is displayed.
2. Use the keypad to enter the phone number (up to 32 digits).
3. Press the SELECT button. The display shows ENTER NAME.
Telephone Operation
17
4. Use the touch-tone pad to enter a name (up to 21 characters). More than one letter is stored in each of the number keys. For example, to enter Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Press the 5 key 3 times for the second letter L, and press the 1 key to insert a space between the first and last name. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H.
5. Press the STORE button again to save your selection. ENTER LOCATION is displayed.
6. Enter two digits to enter the location, ranging from 01 to 40. For example, to store the record in location #5, press “0”, “5”. After entering a valid location number, the record will be saved. If the memory location you selected is not empty, OVERWRITE? will show in the display. Press the STORE button again to confirm the current record and overwrite the old one or press the EXIT button to select another location.
7. To enter another name and number in a different memory location, return to step 1 and repeat the process.
Good Luck.
When I try to type numbers...letters pop up.
press alt or arrow key and select the number key .........repeat the same when u want the number to get displayed in place of letters
Storing #s in memory
Try this. Memory The handset can store up to ten 24-digit numbers with up to 15-character names in memory for quick dialing. This memory feature is in addition to the CID memory log, which stores up to 40 CID records in the handset. Storing a Name and Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the mem button. 3. Press the desired memory location (0 through 9) or use Caller ID/vol (+ or to scroll to the desired memory location. NOTE: If the memory location is occupied, the memory location number and its contents show in the display. 4. Press the mem button again. The display shows ENTER NAME. NOTE: If you don?t want to enter the name, skip step 5. 5. Use the touch-tone pad on the handset to enter the name (up to 15 characters) and press the mem button to save. More than one letter is stored in each of the number keys. For example, to enter the name Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Wait for one second. Press the 5 key 3 times for the second letter L. Press the 1 key to insert a space between the L and the S. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H. 6. Press the mem button to save the name. The display shows ENTER TEL NUMBR. 7. Use the touch-tone pad to enter the telephone number you want to store (up to 24 digits). 8. Press mem again to store the number. You will hear a confirmation tone. NOTE: If you make a mistake press the del/chan button to backspace and erase the wrong character(s) or number(s). If there are any further questions or comments, please post here. Please rate this solution through fix-ya.com Thank you
Top Ambir Technology Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Ambir Technology Office Equipment and Supply Expert? Answer questions, earn points and help others
