Question about ASUS P5VD2-X Motherboard
Boot problems. Are there compatibility problems between this motherboard and Vista? I have about 10% success rate when starting my PC. Usually it gets as far as the 'Microsoft' logo appearing at the lower part of the screen, the yellow flashing light on the PC stops flashing after a few seconds (continues to blink) and nothing else happens. I sometimes have success if I boot using the 'Last known good configuration' option, or carry out a restore back a few days or sometimes a restart from safe mode works. Thanks
  • 558 Answers
_SetupBidi('source');
you probably have a Maxtor hard drive that will have more problems with startup operating system is not on motherboard
Posted on Nov 01, 2009
Testimonial: "Many thanks for your response. I will follow up your suggestion."
6ya staff
SOURCE:
I am having problems with my toshiba satelite laptop mod# A55-s306. following error message appears when it is turned on: PXE-E61: MEDIA TEST FAILURE, CHECK CABLE PXE-M0F: EXITING INTEL BOOT...
What you should do is in the following order:
1.Go into bios and load defaults (usually hit F1)
2.Go into bios and set the boot sequence as HDD number 1
3.Go into bios and disable network PXE boot if possible.
4.Now retry
5.No success press F12 and choose HDD as boot up
6.Now retry
7.No success then remove the HDD clean the contacts and reseat
8.Now retry
9.No success open the laptop lid locate which part of the laptop the hdd is located and just give the laptop a tap in that corner and abit of a push (with the laptop turned OFF) Ive successfully fixed 2 of my IBM's doing this.
10.Still no success try changing the HDD and reformating a fresh
11.Still no success i would open the laptop up completely remove the motherboard and oven bake your motherboard and 375f for 10 minutes BUT BE WARNED DO A GOOGLE SEARCH BEFORE DOING THIS!. This method can also repair other faults such as GPU faults, Memory faults..ect.
May 07, 2011 | Toshiba Satellite A55-S306 Notebook
My Acer Apire One will not boot up normally. Is ok in safe mode, but fails to boot up 9 times out of 10. when it does, I get multiple failure messages usually about not enough memory to execute a...
this is normally due to motherboard failure.but i suggest u to scan for viruses.as u said it fails to boot up 9 times out of 10 this is like as in one out of ten the motherboard starts working if motherboard goes dead this will dead all time.
hoping this will help u
thnx
Jan 04, 2011 | Acer Aspire One PC Notebook
In vista i m getting booting problem
It sounds like your vista boot files are corrupt. You can reinstall vista and leave your files intact. Just select install when you boot your system and choose not to format hard drive. This should clear your problem.
Good Luck
C2S
Sep 15, 2009 | Intel Single Pack, mATX G965 Exp Chi...
Got new PC w/Vista but printer not compatable w/vista. is there a software sollution?
remember, 10% of all printer drivers fail to install successfully with vista. it's been a huge problem ever since its release.
-check canons website for laters drivers and information
-consider windows 7
Aug 02, 2009 | Canon PIXMA MP170 All-In-One InkJet...
I have a 4 year old compaq presario r3000 with xp home edition installed, now the problen is it won't boot because the hal.dll is corrupted or missing, I have been wanting to install Windows Vista Home...
i wud say that plz dnt install windows vista coz tat wud eat up lot of computer's memory and ur computer wnt be running ,,it wud b walking,,and u wud get irritated,,moreover u wud face problems with the 3rd party softwares tat u wud try to installl,,resulting in more problems,,my advice,,go with xp,,easy convenient to use
best of luck,,giv a good rating use,,keep me posted
May 16, 2009 | Compaq Presario R3000 Notebook
Bios flashing.
you download the iflash utility from your manufacture website & you must burn it in cd & then you must insert the cd that s all your bios will get unlocked .....
http://www.softpedia.com/get/Security/Decrypting-Decoding/CmosPwd.shtml
download & break the password with this software ..
easiest method you can do this from the windows also if you didnt enter the boot password for your bios ....
follow the extra instructions in that link :
that s it it very easy to break if you are able to run the windows ...
any doubts reply me
i am always here to assist you
thank you
bye
dont forget to rate my solution
Jul 04, 2008 | Acer Computers & Internet
Hang
Hello there what i think may have been obvious to you. So i will tell you what i think is wrong. You see vista is a very high software and requires motherboards that are top of their game i think you should get you motherboard upgraded to a point where vista rates it to total of 2.5 then everything should run ok. if you want to ask for further assistance write back to this post and i will be ready to assist you.
Jul 02, 2008 | Microsoft Windows Vista Ultimate Edition
Reinstalling Problem
Once you disrupt the partition table by introducing a new linux partition the recovery program is unable to identify the recovery partition. The only success I have had is to boot from a program called partition table doctor and using it to rebuild the master boot record and partition table structure, you can download it here: partition table doctor
of course there is no guarantee it will cure your problem but it is a very powerful tool I have used with some success. Please rate my assistance as we depend on your rating to carry on giving FREE advice.
Mar 29, 2008 | Compaq Presario Notebook
Video Problems.
well, I suppose it could be the motherboard, though I doubt it. I wonder did you check; the board, processor and graphics card on against the vista HCL (Hardware Compatability List) you should be able to find it on microsofts website. Unfortunately being a 64 bit OS, and considering how new it is, very few devices, software and drivers are actually designed to work on vista yet. I hear alot of complaints about vista not working properly. thruth is vista isn't the problem, other companies didn't keep up. anyway, I hope you can fix it. and honestly I hope it isn't a hardware compatibility issue. Either way Good Luck
Jun 18, 2007 | Intel D946GZIS Motherboard
ASUS P5VD2-X Motherboard Logo
102 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
