SOURCE: When Gaggia has finished brewing the group head is full of water
check silenoid valve maybe he dont release pressure
SOURCE: GAGGIA TITANIUM........WEAK COFFEE
Try adjusting the grind finer, if that does not help then go to menu and make sure pre infusion is enabled.
SOURCE: The brew unit is not tamping the ground coffe properly.
Give the brew unit a good wash,then lube all the moving parts with food grade grease.
If you are able dismantle the brew unit and wash in warm soapy water,this removes coffee and any old lubricant.
SOURCE: My gaggia titanium says it's brew unit is blocked
Try cleaning and relubing the brew unit.
If that fails you require a new main board.
SOURCE: Gaggia Evolution is overheating
Check the thermostat on the side of the boiler, that might be damaged.
