There is only one issue: The VGA section does not appears for Windows 2003. May I use drivers for other OS? I tried with XP drivers provided in installation DVD and said: "No supported WIN NT _5.1"There is only one issue: The VGA section does not appears for Windows 2003. May I use drivers for other OS? I tried with XP drivers provided in installation DVD and said: "No supported WIN NT _5.1"
You can't post conmments that contain an email address.
Don't see a Server2003 Driver Set on the ASUS Web Site. You can use the XP Drivers. Goto: usa.asus.com/support/downloads find your motherboard. To start look under the 775 Socket... they ask that first then locate P5KPL-AM/PS.
Once installed... MS update will correct or update the Drivers.
Run all of the MS updates after you install all drivers...even external drives. Then load your add-on software last... AntiVirus, etc...
Click the drop-down button & click on your operating system.
The SM-Bus controller is installed with-in the chip-set driver.
Intel(R) P45/ICH10R Chipset Software Installation Utility WHQL V9.0.0.1009 for Windows XP/Vista & 64bit XP/Vista.
Normally this is installed after a fresh install of windows. However if windows is giving you trouble you can re-install the chip-set driver utility. Than check windows for any updates.
I will give you a
alternate and easy way for your problem.Just download this software
named driver magician and install it.It will search for the drivers for all your hardwares and components that doesnt have proper drivers and will download it.It will make your problem easy
