PNY 2GB Secure Digital Memory Card Logo
Posted on Oct 31, 2009
My sd card is showing a writing protection, how can I remove it?
Anonymous
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Oct 31, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
7681
Points
55
On the side of your SD card there is a sliding button type thing. Try moving it and seeing if this removes your write protection issue.
3 Related Answers
Anonymous
  • 948 Answers
  • Posted on Jul 17, 2009
SOURCE: write protection
There is a small switch on the card. The Sandisk site has a photo of a larger card, smaller cards like the microSD must be inserted into the standard SD adapter.
Anonymous
  • 32 Answers
  • Posted on Mar 03, 2010
SOURCE: remove write protection from micro-sd card
  1. Remove the Sandisk SD card from your portable electronic device. Ensure that the SD card can be safely ejected before removing.
  2. Locate the write protect lock. The write protect lock should be on the side opposite the cut-off corner of the SD Card.
  3. Disengage the write protect lock. To do this, gently slide the small switch upward, toward the top of the SD Card. The card should now have write protection disabled.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
elix0411
Jose Cada
  • 3530 Answers
  • Posted on Apr 03, 2010
SOURCE: How do I remove write protection from micro scan disk chip?
if you will look into the side of your SD CARD. theres a small toggle switch there. just slide it to the other side inorder to disable the write protection
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
I wanna turn off a write protection mode on an SDXC card
How to remove write protection from SD Card
Click on above link and watch the video. It will show you how to remove write protection.
Semper Fi,
Z
Nov 13, 2018 • Cameras
Remove write protection on sd card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
1helpful
2answers
How do i shut off write protection
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
1helpful
My micro sd card is locked how to unlock
3helpful
When i try to format my micro sd card system shows remove write protect how can i format it
I hope this helps.
Sd write protect is showing when i turn on camera how do i remove x-43 model
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
How to remove the write protected micro sd card?
SD cards allow you to store digital information; you can use SD cards with most electronic devices like digital cameras and computers.
An SD card will become write protected if the switch on the card is placed on the "Lock" position. This prevents any information on the card from being altered or deleted.
If you wish to add, delete or change any of the information, you must remove the write protection.
Remove the SD card from the computer or digital device.
Locate a switch on the bottom or side of the SD card.
Move the switch to the "Unlocked" position to remove the write protection.
If you do not have a switch, you will need to remove the write protection with your computer.
Insert the SD card into your computer's card reader or back into the digital device.
You can now save and change information on the card.
13helpful
2answers
My microsd 2gb memory card show write protected.plz help me
You will need to use a regular SD Card Adapter for the micro sd card. The micro sd card itself does not have a write protected switch, but a regular SD card adapter will, and that does affect the microsd card. You just need to put it in an adapter, flip the switch to make sure it knows it is "locked" - so switch it to locked first, then switch it to unlocked. From there you should be able to write to the card. If you can not then it is possible the micro-sd card is having physical problems and may need to be replaced. Here is a little diagram showing how to unlock the card. Before you go though please make sure to rate my answer 4 thumbs up, it is extremely important to me for you to do so. I would be forever grateful!
Here's the link:
http://www.instructables.com/id/Remove-the-write-protection-on-a-Micro-SD./#step1
Thanks
Tim
2helpful
Remove write protection from micro-sd card
2helpful
2answers
Write protection problem of my mobile memory card
Hi..
To remove the right protection it is very simple, first remove your SD card in your mobile, the observe your SD card back to back, if you can see a small button you need to slide that button to remove right protection, then plug your SD card back to your china mobile and try to copay a folder,
Good luck !!!
Regards
PCmania
Top PNY Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
