Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
TV is not responding - JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Posted by smummert on
SD Tech
    Top Expert:
  • JVC Master
  • 14,553 Answers
Your description does not tell me very much---You have a JVC AV-56WP74 and it does not work?
If the power light up front which is usually blue in color just blinks I can tell you a easy way to know exactly what is causing this problem.
If when you turn the set on the blue power light just blinks---that is short protection--most of the time a fairly cheap fix----LET ME KNOW WHAT YOU ACTUALLY HAVE GOING ON.
I am here to help---I do this here for free.
Do not hesitate to ask me for help or advice.
Regards, SD TECH
Posted on Oct 31, 2009
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
LT-24DG42J
013/ 054/ 055/ 060/ 065/ 067/ 089 These are the three digit codes to Jvc brand TVs. As there is no remote control with you, the first thing to know is, to which code do your TV respond. Some TVs will respond to three digit codes, some others will only respond to four or five digit codes. If your TV do respond to three digit codes, a universal remote control, which have the above said codes in its code list will work. If you wish to get three, four & five digit code list to some popular remote controls, check the links given above. You can choose the proper remote control to your TV. But before buying a new remote control, make sure about the number of digits of codes that TV must have.
Feb 23, 2013 | JVC Televison & Video
Need code for Sansui TV
sansui: 1929, 1911, 1904
or use the general programming tool:
SEARCHING FOR YOUR CODE
If your device does not respond to the remote after
trying all codes listed for your brand, or if your
brand is not listed, try searching for your code. For
example, to search for a code for your TV:
1. Press TV once.
2. Press and hold P until the red LED blinks
twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power.
The remote sends IR codes from its library to
the selected device, starting with the most
popular code first.
5. If the TV responds, go to step 6. If the TV
does not respond, press CH+. The remote will
try the next code. Continue until the TV
responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED
blinks twice.
7. To search for other device codes, repeat steps
1 to 6, substituting the appropriate device
key.
Mar 31, 2009 | Radio Shack 15-2142 Remote Control
Tv is on but wont play
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Give the brand name and the model number..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 25, 2008 | Televison & Video
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Samsung BN59-00599A Remote Control
TV does not respond to remote
Sounds like the sensor on the television has gone bad, since it works for the VCR. Try a universal remote that you can program the TV and VCR codes into and try it out. If it works for the VCR and TV then you know it's the remote, if the TV still isn't responding then your TV sensor is toast.
Jan 03, 2008 | Zenith B27A11Z 27" TV
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
122 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
