Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Printer no longer prints legibly
My Canon MP390 printer (even with brand new ink cartridges) has recently begun printing faded documents.
I've played around with the settings, and even cleaned the nozzles, but the problem persists.
Please advise.
Posted by magicmarkr on
Anonymous
    New Friend:
My CLP-300 color laser printer does not print clear in black. The left side of the page is worse then the right side. what can be done to fix this problem
Posted on Oct 30, 2009
The printer's lying to me
The printer requires both cartridges to have ink before the printer will initialize and operational. Even if you are only printing black and white both cartridge have to contain ink or the printer will error out. This is standard on all ink jet printers from every manufacturer. You will have to get ink before you can print.
Apr 28, 2013 | Canon Pixma MX410 All-In-One Printer
I'm having a problem with the ink magenta on an IP4500 Canon Printer, it's not printing any magenta even with new cartridges and I've done all the maintenance checks!! Help!
there are small metal spring contacts between the cartridge holder and the cartridge itself, these send the signals to the print head via the cartridge holder. Over time, as a print cartridge moves from side to side during printing these flatten out and no longer come into contact with the cartridge. Find the contacts behind your magenta colour cartridge and re-tension the spring metal contacts so they once again contact the metal faces on the cartridge. They maybe hard to find as they will be in the place where the cartridge goes, use the flat copper faces on the cartridge to give you a clue as to the position of the contacts in the holder.
Apr 16, 2012 | Canon iP4500 Photo Printer
I installed a new Ink Cartridges in My Canon Multipass MP390 color inkjet printer and now it won't print, Though the machine is on the compartment that carrys the ink cartridges wont even move as it its...
Hi Good day!! well i know that you can fix it. 1st off all is there any message error in your printer? if none then we will try to troubleshoot it in the printer spooler. Printer spooler is located in the services. please try the following.
1. turn off in a few seconds and then turn it on see if the ink cartridge is moving.
2. Click "Start
3. Click "Setting
4. Click "Control Panel"
5 Click "Administrative tools
6. Click "Services you should be on the services box now.
7. in the service box find "Printer Spooler
8. Click "Printer Spooler" all you need to do is to restart the printer spooler Stop and then START it again.
Try to print now hope your ink cartridge move..
ReGARDs
JR
Oct 07, 2010 | Canon MultiPASS MP390 All-In-One InkJet...
Black 3e won't print, even with NEW printhead.
Hello!
Please check the "Rplacing an ink tank" part of the manual. Hope it will help you.
https://manualsbrain.com/en/manuals/1796179/?page=45
Oct 24, 2017 | Canon PIXMA MP780 All-In-One InkJet...
Trapped ink cartridge on printer
Instructions
1. Step 1
Remove the printer inkjet cartridge from the printer. Inspect it to make sure that it truly has ink left in the sponge that is worth going after. If it is dry, this method will not help you get any more out of it.
2. Step 2
Get your blow-dryer from the bathroom, or take the printer ink cartridge to where the hair dryer is.
3. Step 3
Hold the cartridge a few inches from the mouth of the blower.
4. Step 4
Blast the printer inkjet cartridge with hot air from the dryer for a couple of minutes, turning the cartridge so that all sides are warmed.
5. Step 5
Replace the printer inkjet cartridge back into the printer.
6. Step 6
Print your document. This should free up enough ink to print a few more documents. It does actually save you money to do this, even considering the cost of the electricity to melt the ink. The ink in printer inkjet cartridges is the most expensive liquid on the planet. Use every drop to your advantage.
Jan 26, 2010 | Canon SmartBase MP390 All-In-One InkJet...
I put new ink in my mp390 and it is not printing anything it says the printer is online and when I hit print all that comes out is a blank sheet
Hi, i suspect the ink you bought is not compatible with the printer, try print test page and see what happens.if it is still blank,then, change the ink cartridge.
Compliment and wish you best of luck.
Jan 02, 2010 | Canon MultiPASS MP390 All-In-One InkJet...
How do I direct my Canon ip4300 Printer to no longer print from the normal black 5BGBK cartridge (empty) but to print from the 8BK (full)
You can't because CLI-8Bk ink cartridge is use only for photo printing.For text, document or gray scale printing the printer use PGI-5Bk.You need to replace your empty PGI-5Bk.
Oct 19, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
I have Canon MP 390 and no printing
Fill up the cartridge as printer software does not always monitor right ink level even its happens to me many times but fact is cartridge is empty fill it up thats it
Feb 11, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Printer Problem
Hello Dear,
The nozzles of the print head are jammed. you can try this take about 50 ml of luke warm water (please ensure that the temperature of the water is not too high as it may spoil the print head physically) in a small flat base dish and keep the print head in it (only the bottom part the nozzles should be dipped and not the green circuit chip) for about 30-40 minutes there are about 40% chances of print head recovery, if this solves your problem them its ok or you have to purchase a new Print Head for your printer.
Warm Regards,
Manoj Joseph
+91 9352008418
Mar 25, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
178 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
