Question about Jl Audio 300/4 Car Audio Amplifier
The light yellow is on what hapen whit my ampli
Posted by parra92211 on
AceBoogie
    New Friend:
I have a Rockford Fosgare Punch p4004 amp 1200 watt 2/4 channel Amp and the Yellow Thermal indicator light pops on what is goin on or wrong with my amp? I'm using it for my highs and its connected to my Quantum 3000 watt Amp.
Posted on Mar 08, 2013
Anonymous
    Problem Solver:
  • 9 Answers
Depending on what light it is. It could be your ohm light, if it is your ohm light then you have something wired incorrectly. If it is another light, it could either be a power problem or it could be that your amp is damaged.If you would like, you may e-mail me and u can let me know which light is on. It SHOULD say right next to the light; which light is on. E-mail me at [email protected] and I will respond to you as soon as i recieve it.
Posted on Nov 05, 2009
MY SOUNDCRAFT EFX8 IS CAUSING MY AMPLIFIER LIMITER TO KICK IN, AND CAUSING SOUND CUT OUT
Usually is because the signal exceed the input limit of the ampli.
I don't know which ampli do you use, but it should be a pro ampli with balanced inputs correctly able to manage +4 dB professional signals.
Try not to exceed 0dB in the master section of your mixer and let me know.
Oct 14, 2015 | Soundcraft Music
IS YAMAHA AMPLI RX SERIES RIPP OFF
Maybe the problem is with your speakers. Shorted speakers or speakers that are being over-driven can cause the receiver to shut down and possibly be damaged.
May 21, 2013 | Yamaha Rx-v465/rxv465 Home Theater...
I can hear people but nobody can hear me
you blew the finals out
another words
take it to the repair shop 20 - 50.00 to get it fixed usualy it hapens when a dim whit keys up the mike without a properly matched antena attached eithor due to stupidity or lack of knoledge or plain accident and not reading instructions they came with the radio
ask the repair guy what size antena will be required when droping off the radio
Jul 30, 2009 | Cobra 29 LTD CB Radio
I have a clear picture but no sound when operational.
is the red yellow and whit cord plugged in the whit 1 is the sound yellow is screan
Jul 10, 2009 | Microsoft Xbox 360 Console
HP DESKJET 1280
I have the same problem. Yellow light now constant and will not print at all.
Oct 11, 2008 | HP DeskJet 1280 InkJet Printer
Problems with the ampli
can i joine the ampli with computer
Oct 17, 2007 | Autotek XS-900.2 Car Audio Amplifier
Amp turns on and stays on but no sound
are you shure you not connect the amplifier in a wrong connection ...B+,GND,ACC.....ok...then checkif the speakers wires stay in good condicions, some times when we intalled the spk wires for the border of the doors a few times skrewered too.check if it hapen. another ....check if the terminal spk is not going at ground whit the chasis another to....4 ohms per channel ,anny voice coil spk burned...in short. good look.
Mar 10, 2007 | Sony XM-2200GTX Car Audio Amplifier
Jl Audio 300/4 Car Audio Amplifier Logo
289 people viewed this question
Top Jl Audio Car Audio & Video Experts
Marvin
Marvin
Mike
Muntejaya Ginting
Muntejaya Ginting
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
