Question about Whirlpool Duet GHW9150P Front Load Washer
How do I change the pump on a whirlpool duet washer - specifically, how do I get the clips off of the hoses?
Posted by stanfordlawy on
steve
  • Whirlpool Master
  • 3,361 Answers
His Duet manual should help you.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Posted on Oct 30, 2009
My whirlpool duet front load washer is giving a F21 error code. It will not drain. When I blow into the drain hose on the back of the washer it will start draining. But everytime I run a new cycle it will...
whirlpool duet front load washer this video is on a bosch but it will help you Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL DUET WASHER THE WASH LIGHT IS NOT LIGHTING UP WHEN WASHER IS STARTED AND THEN I GET "LF" CODE
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Oct 12, 2012 | Whirlpool WFW9151YW Duet 3.5 cu. ft. Front...
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not drain. It sounds like the motor for the pump is running but nothing is coming out. Whirlpool Duet washer.
It sounds like you may have a kinked drain hose or an obstruction in the hose coming out of the tub to the pump. The pump filter screen may also be clogged.
Are you getting any error codes?
Mar 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water has started pouring out from under my washer
Hello, you've indicated this problem only arrises during the rinse cycle, is that correct ? The leak doesn't occur during the wash cycle initial fill level ? I want to distinguish the difference because there has been a repair tip issued by whirlpool for the duet and sport washer's. This may be applicable to your machine. If it is indeed only during the rinse, the problem is within the door assembly. Specifically the glass and it's "seat" to the frame. Let me know, I'll watch for your reply. macmarkus :)
Mar 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I get the error code S02 on my Duet washer. It
02 is a slow drain,
yopu can check your pump
take off the back wall and hoses,, have towels ready
you will loose water,,
inspect the inside of the pump and all hoses
Oct 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer will not spin out water, shows F02, already checked the hose for kinks and/or clogs?
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer not spinning/draining and it's showing me a code (F21)
clean the drain -here are a few postings i used to fix my Whirlpool ****-eettt (Duet)10 minutes ago. google whirlpool duet there is a 5 min video by jim that walks through the whole gig. 3 screws a twist & you're done your correct so lets fix it...take bottom acess panel of ..theres three screws,,,ok ready clean that pump filter it right in front of you twist it out always unplug first unplugged good,,now while your down there with the filter out,,check booth black hose to make sure theres no coin or hair clips while you have it open,,onthejob
Mar 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT F 09 electrical problem
f09 is a overflow conditioncheck pump,drain hose not kinked,drain pump failure,pressure switch.
Oct 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
254 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
