The driver door module (DDM) is connected on the standard corporate protocol (SCP) communication network. The DDM controls many functions including power windows, power door locks and remote keyless entry. The DDM also communicates with the driver seat module (DSM) to control the power mirror and seat memory functions.
Do you know anything about automotive electronic control modules ?
The driver door module (DDM) receives inputs from the digital transmission range (DTR) sensor, ignition switch, seat switch, window/door lock switches, lighting control module (LCM), keyless entry keypad switch and remote transmitter. The DDM outputs consists of keyless entry keypad switch illumination, power door lock actuators, luggage compartment release solenoid, horn relay, and lighting control module (LCM).
Best thing to do would be to have a factory scan tool hooked up to check for DTC'S diagnostic trouble codes . That should be the first step if it's not programming the code.
PINPOINT TEST L: THE DOORS DO NOT LOCK/UNLOCK USING THE KEYLESS ENTRY KEYPAD
CONDITIONS
DETAILS/RESULTS/ACTIONS
L1 RETRIEVE THE RECORDED RESULTS FROM BOTH CONTINUOUS AND ON DEMAND SELF TESTS
Use the recorded DDM DTCs from the Continuous and On Demand self tests.
Yes For DTC B1525, GO to L3 .
For all other DDM DTCs, REFER to the DDM Diagnostic Trouble Code (DTC) Index.
No If the door locks are inoperative, GO to L2 .
If the keypad illumination does not operate, GO to L10 .
If the keypad illumination is on continuously, GO to L14 .
L2 CHECK THE DOOR LOCK OPERATION
Check the door lock operation by depressing a door lock switch.
Yes GO to L3 .
No GO to Pinpoint Test E .
L3 MONITOR THE DDM PID KEY_PAD
Scan tool
Monitor the DDM PID KEY_PAD.
Yes GO to L4 .
No GO to L5 .
L4 CHECK THE KEYLESS ENTRY KEYPAD SWITCH
Keyless Entry Keypad Switch C525
Yes If 1/2, REPAIR Circuit 78 (LB/YE). TEST the system for normal operation.
If 3/4, REPAIR Circuit 79 (LG/RD). TEST the system for normal operation.
If 5/6, REPAIR Circuit 121 (YE/BK). TEST the system for normal operation.
If 7/8, REPAIR Circuit 122 (YE). TEST the system for normal operation.
If 9/0, REPAIR Circuit 123 (RD). TEST the system for normal operation.
No INSTALL a new keyless entry keypad switch; for additional information, REFER to Keypad-Keyless Entry .
L5 CHECK THE KEYLESS ENTRY KEYPAD INPUT WITH THE KEYLESS ENTRY KEYPAD SWITCH
Monitor the DDM PID KEY_PAD, while depressing all the keyless entry keypad switches one at a time.
Yes GO to L9 .
No GO to L6 .
L6 CHECK CIRCUIT 797 (LG/VT) FOR VOLTAGE
Keyless Entry Keypad C525
Measure the voltage between keyless entry keypad C525-7, Circuit 797 (LG/VT), and ground; and between keyless entry keypad C525-8, Circuit 797 (LG/VT), and ground.
Yes GO to L7 .
No REPAIR Circuit 797 (LG/VT). TEST the system for normal operation.
L7 CHECK THE KEYLESS ENTRY KEYPAD SWITCH INPUT
While monitoring the DDM PID KEY_PAD, momentarily connect a fused (7.5A) jumper wire between positive battery post and keyless entry keypad switch C525 as follows:
Keypad Button
Keyless Keypad Switch C525
Circuit
1/2
Pin 3
78 (LB/YE)
3/4
Pin 4
79 (LG/RD)
5/6
Pin 5
121 (YE/BK)
7/8
Pin 6
122 (YE)
9/0
Pin 1
123 (RD)
Yes INSTALL a new keyless entry keypad switch; for additional information, REFER to Keypad-Keyless Entry .
No GO to L8 .
L8 CHECK THE KEYLESS ENTRY KEYPAD SWITCH CIRCUITRY FOR AN OPEN
DDM
Measure the resistance between keyless entry keypad switch C525 and DDM as follows:
DDM
Circuit
Pin 3
C521 Pin 8
78 (LB/YE)
Pin 4
C521 Pin 13
79 (LG/RD)
Pin 5
C521 Pin 16
121 (YE/BK)
Pin 6
C520 Pin 24
122 (YE)
Pin 1
C520 Pin 25
123 (RD)
Yes INSTALL a new DDM; for additional information, REFER to Section 419-10 . TEST the system for normal operation.
No REPAIR the circuit in question. TEST the system for normal operation.
L9 CHECK THE KEYLESS ENTRY KEYPAD BACKLIGHT
Depress a key on the keyless entry keypad.
Yes INSTALL a new DDM. For additional information, REFER to Section 419-10 . TEST the system for normal operation.
No If the keypad illumination does not operate, GO to L10 .
L10 CHECK THE KEYPAD - DDM ACTIVE COMMAND KEYPAD BACKLIGHTING LIGHT ON AND OFF
Trigger the DDM active command KEYPAD BACKLIGHTING LIGHT ON and OFF.
No GO to L11 .
L11 CHECK DDM GROUND - JUMPER CIRCUIT 66 (LB) TO GROUND
DDM 522
Connect a fused (7.5A) jumper wire between DDM C522-4, circuit 66 (LB), and ground.
No GO to L12 .
L12 CHECK CIRCUIT 51 (BK/W) FOR OPEN
Measure the voltage between keyless entry keypad C525-7, circuit 797 (LG/VT), and ground; and between keyless entry keypad C525-8, circuit 797 (LG/VT), and ground.
Yes GO to L13 .
No REPAIR circuit 797 (LG/VT). TEST the system for normal operation.
L13 CHECK CIRCUIT 66 (LB) FOR OPEN
Measure the resistance between keyless entry keypad C525-2, Circuit 66 (LB), and DDM C522-4, Circuit 66, (LB).
No REPAIR Circuit 66 (LB). TEST the system for normal operation.
L14 CHECK THE KEYPAD ILLUMINATION - DDM DISCONNECTED
DDM C522
No GO to L15 .
L15 CHECK KEYLESS ENTRY KEYPAD FOR SHORT TO GROUND
Yes GO to L16 .
No INSTALL a new keyless entry keypad switch. For additional information, REFER to Keypad-Keyless Entry . TEST the system for normal operation.
L16 CHECK CIRCUIT 66 (LB) FOR SHORT TO GROUND
Measure resistance between DDM C522-4, circuit 66 (LB), and ground.
Yes System OK. CLARIFY the concern with the customer.
No REPAIR circuit 66 (LB). TEST the system for normal operation.
SOURCE: trunk won't open in 1994 lincoln towncar
You can get a good locksmith to make a key...last time I check it ran about 30-$50.
SOURCE: Lincoln trunk motor/latch
check the bolts that hold the motor assembly on. they may of came loose or are broken.
SOURCE: i have a 1993 lincoln
Check little finger like/half moon part of latch on lid & see if it comes across, and locks in. Use a screwdriver or something. Then turn key & see if it snaps back. See what you find & get back to us. Don't be afraid to lubricate all that in there while your at it.
SOURCE: 03 Lincoln Towncar trunk malfunction
Sounds like the lift drive assembly is screwed up if it falls shut when trying to open it. Haven't worked on these so they may have a safety feature that drops the trunk if it hits something. Is some blocking the hinges travel as it opens?
SOURCE: fuse # for 1991 lincoln towncar trunk latch motor
1995 lincolntowncar trunklatchmotor trunk will not closeall the way
