This sounds as though the pump belt is slipping. This may be caused because the pump belt has stretched slightly or the pump is seized and will not turn. Remove the pump belt and turn the pump rotor with your fingers to see it turns freely. If it does then the pump should be OK but the belt may be stretched and will need replacing. If the unit does not spray after changing the belt then clean the spray nozzles at the front of the machine and make sure that water flows to the nozzles OK. You can check this by temporarily disconnecting the nozzles from the plastic pipes.
Main causes for no spray.
Bladder may be empty.
SmartMix Bottle may be empty.
The Filter may be clogged.
Tanks may not be seated properly.
Pump may have lost prime. Check all the fluid tubes / hoses for leaks or blockage (see below).
The Pump Belt may be broken.
2 front jets are blocked. This is a common problem. When the machine is standing for a while the detergent turns to a gel causing the blockage Lay the Bissell on its side then where the water comes out of the jets at the bottom of the machine unblock them using a pin to poke through the hole in the centre.
Try running hot water through the system with no detergent to empty out all the residual detergent. Keep running hot water through the system by pressing the button you press for it to spray the water do this for about 5 mins and keep swapping the water for hotter water as it starts to cool doing this 4 or 5 times might solve your problem if not get the tools out and start looking for the blockage. Do this once a month to ensure that the pipes and jets are kept clean and free of any detergent gel build up.
