Question about Pitney Bowes C180 Copier
C180 says E2 and printer tray light blinks
Imagistics pitney bowes c180 copier says E2 and printer tray light blinks. Is there a code to reset this machine or what this code means?
Posted by abigailohlse on
Tareq Bin Mostaq Mostaq
    President:
  • Pitney Bowes Master
  • 1,449 Answers
E2 means paper miss feed press resum button the go to print
Posted on Oct 30, 2009
  • Tareq Bin Mostaq Mostaq
    please follow your peinter user guide troubleshooting E2 mean paper jam or any kinds of jam
Error code C0110 on imagistics copy machine which model number is C650
The only reference to that particular code is:
C011
Backup memory problem
Problem with thebackup memorydata.Defective backup ram.
Jan 21, 2013 | Pitney Bowes 460-4 Toner for Imagistics...
Pitney bowes c 180 copier red wrench error
The red wrench is a maintenance indicator. Your Pitney Bowes C180 is made by Panasonic and is a model FP7718. I was going to type up the maintenance reset procedure but I will just give you a link to a page that has step by step instructions. Here it is:
http://www.copytechnet.com/forums/panasonic/6754-panasonic-fp-7718-maint-counter-reset.html
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 31, 2010 | Pitney Bowes C180 Copier
I have a pitney bowes C180 that won't copy. The
the little wrench means it has shut down because it has exceeded the maintenance count, probably for the cleaner web in the fusing unit. Call service at 1 800 243 5556
Oct 30, 2009 | Pitney Bowes C180 Copier
My pitney bowes c180 copier after turning on it started to work but after a while E 340 displays on the top board what will i do to fix it?
There is a sensor by the drum that checks the image on the drum. If the sensor is dirty, or the image on the drum is too dark, it causes this code. 18002435556 for service.
May 11, 2009 | Pitney Bowes C180 Copier
FAULT CODE P0500
Fuser error code. unbend a paper clip and push in hole on right side of control panel. watch the control panel on the left side about 2/3 up a dot will appear. when it shows up, press 3. press trouble reset. Touch exit.
turn machine on and off. If it comes back up, reset again. 3rd time it needs a new fusing unit. Call 18002435556 for service.
Jan 05, 2009 | Pitney Bowes C180 Copier
Pitney Bowes C180 copier: what does a U16 code mean?
Develepor unit failure. Did you by any chance remove the Develepor unit? or did you come close to the wire connector located behind the toner bottle if so reconnect it. NOTE ! Before checking any connector make sure the power is off and not plugged into the wall outlet ....Good Luck
Nov 26, 2008 | Pitney Bowes C180 Copier
C180 copier error code E7
The e7 code is for the sorter problem. you can either call for service 18002435556 or just remove the sorter and use the copier without it.
Oct 19, 2008 | Pitney Bowes C180 Copier
PITNEY BOWES C180 COPIER
Contact OCE to find a dealer in your area. There the ones handling service on Pitney Bowes copiers.
Jul 29, 2008 | Pitney Bowes C180 Copier
Service Manual
A good place to find one is on copytechnet.com. I checked some of the service manual websites and nothing was comming up with that model number. It could be because Pitney Bowes spun it off into Imagistics and now it's called Oce. Usually the copiers are made by Ricoh. Someone on there would know where to get the service manual under the Ricoh model number as well.
Jul 10, 2008 | Pitney Bowes C180 Copier
Pitney bowes c180
Try making a copy in Photo mode and see if it makes a difference
Nov 18, 2007 | Sharp AL 1631 Copier
287 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Marvin
Marvin
john h
Tom Chichester
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
