Question about NorStar Meridian M7310 Phone
Have Norstar M7310 5 line phone 2 lines say they
Have Norstar M7310 5 line phone, 2 lines say they are in use, but they are not? Checked and unplugged phone, still say "in use"?
Carl Navarro
  • NorStar Master
  • 2,460 Answers
You need to unplug something, just not the phone.
The two lines are probably conferenced together. Go find the gray Nortel cabinet and pull the plug on it.
Carl
Posted on Oct 30, 2009
Testimonial: "Thanks Carl, that worked."
Caller ID not working on Norstar terminal using line dedicated to fax and phone
You must have latest software to have Caller ID
You must have a Caller ID line card
Caller ID must be programmed on the phone to allow it
Caller ID signal from carrier is sent between 1st and 2nd call
FYI on the fax: Analog ports (ATA's) on the Norstar system do not show Caller ID, instead you would need to use a line share device that supports caller id such as the STICK.
Oct 25, 2012 | NorStar M7310 Corded Phone
Lines 1 abd 2 on Norstar phone are showing as being used, however, no phone being used
You probably have two lines conferenced together. The fastest way to fix it is to unplug the system cabinet. It drops the conference and releases the lines.
Carl
Oct 31, 2011 | NorStar T7316E Corded Phone
Norstar phone m7324 1. What is the difference between the name of the "line" and the name of the "set"? 2. Is there a way to reset the lines other than unplugging the phone system? Four lines are showing...
1. You can name the lines, for example (Line 1, Line 2) - or - (5551234, 5551235). You can also name the sets (phones), so when Joe calls Mary, Joe's phone will display "Calling Mary", and Mary's phone will display "Joe calling".
2. Press the line button for the line in use and the display will show which extension is using that line. There could be a stck button on a phone that is tying up the lines. When you figure out which extension is causing the problem, try unplugging it to see if that clears the problem (it should). Then get the trouoble phone repaired. Good Luck!
Mar 15, 2010 | NorStar M7324 Telephone
NORSTAR M7310 Needs to swap primary line
To find the programming codes for your phone, click on this link.
http://tiny.cc/U3cIt
If this doesn't help you can
Call a Norstar Service Technician
800-527-4663
Feb 02, 2010 | NorStar M7310 Phone
We lost power and when our Meridian M8X24 phone system with T7316E phones came back up we only have access to 2 lines. How do we gain access to the other lines again.
Sounds like your norstar system needs to be reprogrammed because norstar defaults back to only 2 lines when the inturnal battery fails.If the inturnal battery has failed and you reprogram this phone system and you have another power fail you will have to have you system reprogrammed again.Time for new system.
Sep 30, 2009 | NorStar T7316E Corded Phone
Lines
You have to go into progrmming and reassign those 2 line to ring on your phone m7310 because those 2 line are not assigned to ring at your phone. Please let me know if you are having trouble getting into programming.
Oct 23, 2008 | NorStar M7310 Corded Phone
Cannot drop line 2
The quickest and dirtiest way is to unplug the system cabinet, wait 20 seconds, and plug it back in.
Carl
Aug 28, 2008 | NorStar T7316E Corded Phone
Can't make outgoing calls
You have to press a Line to call out. Line 1 or Line 2 or Line 3
May 13, 2008 | NorStar M7310 Corded Phone
NorStar M7208
Reboot the phone system.
Unplug the main control unit.
Jan 10, 2008 | NorStar M7208 Corded Phone
NorStar Meridian M7310 Phone Logo
451 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
