Question about Sony Bean MP3 Player
SONY BEAN WONT SYNC MUSIC WITH ITS SONIC STAGE SOFTWARE. with what software can i sync music on this mp3 player
Posted by jellison0 on
Anonymous
    President:
  • 803 Answers
--**Windows Media Player**--
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Posted on Oct 31, 2009
How do I add music to my sony bean? whenever i add music to it, it shows up on the computer but not on the player. it just says "no data". I heard that you have to like convert music using...
Yes, you need Sonic Stage software installed in PC to transfer mp3 files in this Sony MP3 Player.
Click Sony Support, select OS running in PC in drop down list to download Sonic Stage software, install it in PC then connect mp3 player with PC and transfer files through Sonic Stage.
Thanks.
Nov 02, 2010 | Sony Walkman Bean NW-E307 MP3 Player
Down loads music that play on media player but won't play throught speaker and shows in file on sony it will not play out the earphones i did delete the music on the sony and put more on but it won't play...
Transfer mp3 files through Sonic Stage software in Sony NW-E307 mp3 player to get sound in its earphones
You can install Sonic Stage software from cd supplied with player or click Sony Support to download it by selecting OS in your computer in drop down list on that page.
Sep 15, 2010 | Sony Walkman Bean NW-E307 MP3 Player
Accidentally formatted bean on pc
Install Sonic Stage software cd in computer or click Sony Support to download Sonic Stage software by selecting OS in drop down list.
After installation, plug MP3 player in computer and transfer mp3 files in player, Sonic Stage will take care of no data format problem as well.
Sep 11, 2010 | Sony Bean MP3 Player
How to put music on it
You need to install Sonic Stage software in computer then hook this Sony mp3 player with computer to transfer music.
Go to Sony Support to download Sonic Stage software if you do not have it or supplied software cd is missing.
Jun 26, 2010 | Sony NW-E505 MP3 Player
How to add music
You can add music files in Sony NW-E305 mp3 player through Sonic Stage software only.
Click Sony Support to download Sonic Stage software, install it in computer and transfer mp3 files in player.
Thanks.
May 05, 2010 | Sony Walkman Bean NW-E305 MP3 Player
I brought bean and accidently wiped off software
No problem,
Install Sonic Stage software in your PC, hook your Sony NW-E305 and it will be fixed by transferring music files.
Click Sony Support, if you want to download Sonic Stage software.
Hope this info will solve your problem.
Thanks.
Feb 11, 2010 | Sony Walkman Bean NW-E305 MP3 Player
A friend of mine loaded my sony walkman nw-e005f with music form his ipod. I want to download the music to my pc. The Sonic Stage software reads it, but won't let it transfer to the pc. What can I do? I...
download the latest drivers, then restart pc, then turn on device, then hook up to usb, then go to start menu, then my computer, then find your device and double-click to open the files.
Or go to media player 11, sync device and transfer the songs to music file.
Nov 13, 2009 | Sony Network Walkman NW-E005 MP3 Player
How do I load music tomy Sony NW-E205 Bean
Try turning the device on before connecting it to your computer
Sep 13, 2009 | Sony Walkman Bean NW-E305 MP3 Player
Music appears on device on laptop but not when playing music
Sony uses it proprietory software for sync with the device. U can transfer the files by just copy and paste cause the device acts as a removable drive, but the player firmware wont recognise the format. I wud suggest u to use Sonic Stage 4.3 to sync with
Jul 04, 2009 | Sony NW-A1000 MP3 Player
Software
You maybe able to use Windows Media Player 10 or 11, if you want to try well connect your mp3 player to the computer now wait a few seconds then go to Windows Media Player ( if your using windows media player 10 i recommend you to update to media player 11 for better results but if not when your on Windows Meda Player look for a link called "Sync" when you've found it click on that.
Now your on "Sync" if should have found your mp3 player now just drag and drop music you wish to have on your mp3 player on the side panel where it's got a little image of an mp3 player.
Once you've added the music, safely remove the mp3 player like you normally would then see if the music has successfully tranfered.
Here is the new Windows Media Player 11 if you haven't got it already.
http://www.microsoft.com/windows/windowsmedia/player/11/default.aspx
Good luck. Hope my solution was helpful.
Oct 26, 2007 | Sony NW-E002 MP3 Player
Sony Bean MP3 Player Logo
Top Sony Audio Players & Recorders Experts
aliasger yq
Alvin Barnabas
Alvin Barnabas
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
