Question about Sharp LC46SB57UN 46 in. LCD HDTV
Should hd connection be in input 2 or 3?
Sharp LC 46SB57UN: should hd connection be in input 2 or 3?
Posted by vickif47 on
Anonymous
    New Friend:
  • 20 Answers
The ideal connetion would be HD colorstream input
Posted on Oct 30, 2009
Where is the HDMI connection on my Sharp LC-46SB57? I installed X1 and cannot get picture. Sharp Input 1,2&3 are grayed out but Inputs 5Roku & 6blue ray work.
The X1 box acts like a set-top cable box. The HDMI output can be connected to any HDMI connector. There are three HDMI connections on the rear of the set. You have the Blu-Ray connected to one of them, Input 6. You should have no issues with connecting the X1 to either Input 7 or Input 8. There is no specific "TV" HDMI connection. You simply use the remote to select the HDMI port that the X1 is connected to.
Nov 18, 2015 | Sharp Televison & Video
HOW DO I CONNECT WIRELESS KEY BOARD TO MY TV. SHARP MODEL LC-60LE650U
Does tv have usb input? Usually usb is for mass storage only, as the tv wont know the driver for a keyboard, but you can try.
Sep 02, 2015 | Sharp 60" LC-60LE650U AQUOS Full HD Smart...
Sharp lcd tv 32 400m. pc input problem, can't fungtions input 5 (blur)
i connect tv cable but vedio is not working only audio is working in top K letter it is showing in screen
plz send solution
chakradhar
9440176800
india
Feb 01, 2011 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
HOW DO I GET THE BLUE BOX ON MY SHARP AQUOS LCD TV TO STOP POPUP
This happens when you are connecting with a coaxial cable. If possible you will need to connect your set top box to the television with a composite/RCA cable and watch tv on input 2 instead of on input tv.
Mar 19, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
How do i unlock inputs 1 2 and 3?
As soon as TV detects signal on input 1, 2 or 3 it will make an input selectable. Supply signal first then select an INPUT. In other words, something has to be hooked up to those inputs before you can select them.
Jan 05, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Component connection does not support progressive scan DVD
No can do the set cant deal with that signal. turn off prgressive scan on the DVD the signal is still a preaty good one. Only blue ray or HD DVD will get the real HD.
Jul 10, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
Blink on Sharp Aquos LC-32D43U
If your using a HD converter box, there is usually a blink when switching from an HD channel to a non HD channel. It is just adjusting from different pictures modes such as changing from a 480i channel/show to a 1080i channel. If this is the case, its perfectly normal.
Jan 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to connect my Sharp LC-26DA5U to my computer as a monitor
There are two possible problems: 1. You are connecting a 15-pin (on the laptop) to the 9-pin (on the TV) connection. This isn't the video-in connection for the TV. The TV has a DB-15 connection near its DVI input connector. You should be using a 15-pin to 15-pin cable. The DB-9 connector on the TV is a serial port for servicing the TV. 2. You aren't enabling the external video port for the laptop. Try hitting Fn+F5 on the laptop to cycle between the three display modes: laptop only, laptop + TV, TV only. Make sure to wait a few seconds after hitting Fn+F5 to let the displays sync up.
Feb 20, 2007 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
Sharp LC-37D4U 1080i picture problem
have the cable company set the box to 720p whic is the native resolution of the set.this will help with quick signal adjustment
Dec 29, 2006 | Sharp LC-37D4U 37 in. LCD Television
Sharp LC46SB57UN 46 in. LCD HDTV Logo
96 people viewed this question
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
