If all the lights are blinking on your Fuji Xerox 203A printer, it is indicating a "Fatal Error" or "Unknown Error" that has occurred.
Here are some possible reasons and troubleshooting steps you can try:
Paper jam - Open the printer cover and check for any paper jams. If found, clear the jam and close the cover.
Toner cartridge issue - Remove the toner cartridge and check if it is empty or low. If so, replace the toner cartridge with a new one.
Imaging drum issue - Remove the imaging drum and check if it is damaged or has reached the end of its life. If so, replace the imaging drum.
Connectivity issue - Check the printer connections to ensure they are securely plugged in.
Firmware issue - Try updating the firmware on the printer to see if that resolves the issue.
If none of these steps solve the issue, you may need to contact Fuji Xerox customer support for further assistance.
take out the toner.. at the left side of the toner, there is a level, unscrew the 3 screws and turn the level to the other side, this will reset your toner. make sure the printer is on when you put back the toner.
the supplier of the toner cartridge told me the drum must be cracked and he will supply me a new one.I appreciate your service and I recomment you for your assistant,thank you.
