Get another memory card. The C360 works with SD and MMC cards, not with SDHC cards. While an SDHC card will fit into the slot, it is electronically incompatible.
If you are looking for software, got to http://support.en.kodak.com/ and download "
"KODAK EASYSHARE Software - WINDOWS Operating Systems"This will help you to copy pictures to your PC.
Please make sure that you're using fully charged battery
Remove the battery, press and hold the power button for 5 seconds and then reinsert the battery..
Try using a different battery to check whether the issue is with the battery..
You may also check the battery poles using a multimeter to confirm this if you do not have access to a different battery..
If the issue persists, service may be required.
Thanks for understanding.
KODAK doesn't sell battery doors for any of their models.
A repair for this fault is 24,47 pounds + shipping to the repair centre.
If you already have the battery door; I suggest you will have a local camera TECH to attach the door to the unit.
Usually when the camera shows an error mgs. it needs a repair
However Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
non-approved battery may be installed in the camera.
CAUTION: Using the wrong batteries can damage your camera. Always use the battery that came with your camera or an approved replacement battery.
