Need replacement part # and wiring diagram for Nordyne Intertherm E1EH O12HA sequencer
Posted by proc_111 on
frankrhoney
  • 89 Answers
Take it to a hvac supply house and they will match it up for you. The wiring diagram will be on the furnace
Posted on Nov 01, 2009
Cynthia Hollingsworth
    New Friend:
  • 9 Answers
Wiring Diagram E1EH-012H from the owner's manual. If you need a better copy, I'll need an email address.
need replacement part # and wiring diagram for - need-replacement-part-wiring-diagram-pgo4udvlobv2sheptnserdfd-5-0.jpg
Posted on Mar 23, 2015
I have intertherm e1eh-015h I just wired up heat
when the thermostat is set more than 2 degrees higher than room temperature the auxiliary heat will run with the heat pump.
Oct 11, 2014 | Heating & Cooling
Intertherm 2312 0r 2512 wiring diagram
http://enora.nordyne.com/Literature/Resarchive.asp#SP AC
Copy this link not sure why the Ac part at the end isn't attached to the link but it is part of it.
Should be able to find any wiring diagram for your Intertherm Ac, which is manufactured by Nordyne.
Hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Feb 26, 2013 | Intertherm P3RA-048K Air Conditioner
I have a unit with a burnt transformer the original transformer has a red blue black on one side and a black with white stripes yellow and red on the other while the replacement has a green and red on one...
Hi, I have a suggestion here that might help. Contact the manufacturer to get an exact replacement sent to you. The manufacturer is Nordyne. Nordyne makes the same unit and private labels it for other companies, like Sears, Westinghouse, Intertherm, etc. Without out the correct color codes identifying the correct secondary (24Volt ) labeling of the wires the colors are meaningless. The colors of the original transformer wires are coded for the original Air Conditioning diagram that was packaged with it. The only standard coloring found on any transformer is for the primary side. i.e. 120 Volts 60 Hz Alternating Current. Those colors are Black for Hot and White for Neutral (or return).
If you get the transformer from Nordyne or a distributed for their products, Installing the new one will be very easy.
Here is the link to Nordyne
http://www.nordyne.com/web/ContactUs.aspx
Hope this helps,
Best Regards,
Mark
Jan 04, 2011 | Intertherm P3RC-030K Air Conditioner
Need wiring diagram for transformer and themostat
http://www.nordyne.com/Literature/7083400.pdf
There is a manual it has a diagram inside. http://www.nordyne.com/Literature/708340b.pdf
That's all the info i could find mentioned at all on the net, I did exhaustive searching....
May 15, 2010 | Intertherm P3RC-030K Air Conditioner
I need a wiring diagram for a intertherm model # e2eb-015,017
Intertherm is Manufactured by nordyne Inc.
Id recommend www.nordyne.com
At least they could get you to the write people that may have the info you need.
Good Luck!
Nov 03, 2009 | Intertherm P3RC-030K Air Conditioner
Anyone have a wireing diagram for a nordyne E1EH-015HA
Intertherm does not offer a wiring diagram for the E1 series anymore. So I have included a link to the E2 series. They are very similar and you may find this service manual helpful for whatever problem you may be having.
http://www.nordyne.com/literature/359a.pdf
Apr 11, 2009 | Heating & Cooling
I NEED THE WIRING DIAGRAM FOR A NORDYNE MODEL #E2EB-017HA
contact nordyne local dealer and they should be able to get on for you. otherwise go to google and search for factor and e-mail them for 1.
Dec 11, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
703 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
