SOURCE: where is fuel relay
The fuel pump relay is only for the fuel pump priming when you turn on the key. After the vehicle starts the oil pressure switch takes over and runs the pump. If the pump is shutting off after the motor is running the oil pressure swith is probably bad. Let me know if i can help you further.
SOURCE: 1994 chevy s-10 blazer
you probably need a fuel pump relay its on the driver side rear corner under the hood
SOURCE: 1994 chevy s10 blazer turns over, won't start
try replacing the fuel regulator,or is the oil cap on tight?the fuel regulator works on base vacumm
SOURCE: 1994 dodge intrepid 3.3l stalls while driving w/o
I have a 1995 Dodge Stratus and I had the same problems last winter it turned out to be the main brain the ECU as they call it It costas about 1200 dollars new but i scored mine from a junk yard for 10 bucks and my car hasnt done it since. They very well may be your problem because i have the same engine in my car its just a smaller body style. look on the net for spaldings used car parts u can look up parts and they usually sell ecus for 75 to a 100 dollars.
Testimonial: "thx for input !"
SOURCE: replace fuel pump in 2001 Chevy Cavalier
remove the gas tank, undo the ring that holds the sending unit , replace fule pump and new sock filter, reinstall
