Computers & Internet Logo
Posted on Oct 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My acer monitor is showing only blues and yellow colors. No reds etc. I tried to adjust it on color resoliution byut didnt work
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Oct 30, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557218
Points
31058
Try a different video-cable.
Try tightening the connections at each end of the cable.
Try connecting the monitor to a different desktop or laptop,
to see if the colours are correct -- it could be the video-card on your computer.
Anonymous
Level 3:
  • Master 466 Answers
Anonymous
Master
Level 3:
Answers
466
Questions
0
Helped
183031
Points
1494
If it is connected through VGA (i.e., not DVI), try checking the cable and connectors. Sometimes they get loose and one of the R, G, or B channels gets lost.
Why do i have a green screen after i turn the screen adjustment screw?
since every display color monitors are only work with 3 primary color which are red, blue and yellow. You could also search it that by mixing these colors, you could get any color your want. Thats how color monitors work. Now in case of green color, it creates by mixing blue and yellow. When you are turning the screen adjustment screw, the red color plug will become lose, makes it appear green.
I hope your got the reason.
Acer 2016W - When powered on, it shows colored lines (blue, green, red, yellow - vertical) and then goes to a blueish-green display color, no deskktop display at all, have tried switching out monitor...
Yep,
When the capacitors start to go out it causes the power supply to not provide the correct voltages. You monitor has the back light power but the 5v power going to the video driver board is not working correctly. Here is a link to a repair guide that will show you how to open the unit, remove the power supply board and what capacitors need to be replaced.
http://www.ccl-la.com/blog/index.php/repairing-the-acer-al2016w-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Color loss
Hi, right click on an empty area of th e desktop, select "Properties," next, pick all areas that will apply: Windows Color and Appearance, Display Settings... make the adjustments, "resolution etc. "Rating the solution is appreciated, thanks."
Monitor colors are not displaying correctly
Hi, At the worst it is a blown monitor, but have hope. 1st try a new or known good lead, between monitor and PC. 2nd put monitor with own lead on good PC. if 1st works = result. if 2nd and monitor is same, suspect monitor, however, if 2nd works ok on other PC, then look at ur vid card. Either way, this test sequence should save you some $. Be lucky.
The 3 colors wires that hook into my pc are yellow, red & blue, but the colors on the pc are: pink, white and blue is there a color match up?
I suspect you've got the audio and video cables mixed up.
Video inputs on monitor will be yellow for video and red/blue for audio. PC end of cable will be round and connect to your video card. Or .. you should have a cable with a 15 pin mini D on both ends or a DVB cable.
The pink, white and blue connectors on your pc are audio connections for speakers/headphones.
Google is your friend
The ... Google is your friend
Color on Acer 191w
Any of the 3 internal wires that delivers the tree color (Reg-Grenn-Blue) is disconected or damaged.
Open your monitor and try to locate that wires...
Good Luck
Best Regards !
1helpful
My Monitor al1916w the color is all purple or blue. No other color appears including white,yellow or red. please help.
TRY MONITOR ON ANOTHER SYSTEM TO MAKE SURE ITS NOT THE VIDEO CARD . IF IT DOES THIS ON ANOTHER SYSTEM REPLACE THE MONITOR, IF IT WORKS FINE REPLACE THE VIDEO CARD IN THE COMPUTER
5helpful
3answers
Colors are off after auto adjust
I seem to have found the solution (and the cause, perhaps?) for this problem!
I was having the EXACT same problem with a monitor I'm repairing for a friend. The capacitors on the power supply board were blown (CapXon capacitors, who'd've guessed), which was keeping it from powering up. After replacing the capacitors, the screen worked beautifully. But it had this weird yellow tint!
The strange part was that pure colors - red, green, blue - all appeared perfectly OK on screen. Curiously, the menus would show in the proper colors, except for one: the manual color adjustment menu, which illustrated "Blue" as a sort of off-green in the icon. Auto-Adjust would always fix the colors for a split second, then go back to yellow. Reset didn't fix it. Color reset didn't either. So, exactly the same problem as above.
The solution I found was hidden within the main menu itself, a sort of "easter egg". <b>Hold the Menu button down while pressing Power, and hold it down until the screen, and menu, appear</b>. There will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. Voila! PERFECT COLOR! Perhaps this menu was accessed by accident, and calibrated to an incorrect color key. But now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Hope this helps some people, it sure saved my ****! ;)
Blue and yellow color
Blue should converge on top of "yellow".Bad connection(s)
on blue convergence IC.Replace both IC's for durable repair.
Check pico fuses.Reset convergence alignment.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
