Washing machine agitates during wash cycle then stops before rinse cycle. It sits for a while then starts working again. You can smell like a burning rubber smell when it is stopped. Overheating?
  • 62 Answers
Sounds like the belt may be starting to slip and if not its the motor
Posted on Oct 30, 2009
6ya staff
SOURCE:
Top Loading Washing machine Stopped working mid-load
You may find a piece of clothing has jammed the lower spinner or the mechanism is worn and jammed up.
Mar 06, 2014 | Washing Machines
No agitation on extra rinse cycle on Maytag Washing Machine MAV8557AWW
The manufacturer may have found there was little or no advantage to having agitation in the second rinse cycle so omitted it.
Jan 08, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
GE Wizard Top-Load Washer - Burning Smell
sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
Jul 07, 2009 | Washing Machines
Washing machine does not drain during rinse cycle?
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
May 17, 2009 | Whirlpool LSQ9600L Top Load Washer
Washing machine not agitating during wash cycle. Only when rinse
This occurs when your transmission has failed & requires replacement.... Good luck!... Bill
Apr 28, 2009 | Maytag MAV4755 Top Load Washer
Kenmore stackable washer and dryer
check the belt, pulley, & idler pulley assy.
Jul 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
140 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
