Question about Whirlpool Duet GHW9150P Front Load Washer
Can I get pictures/diagrams and instructions on removing the mcu board(duet ghwn150pw3) to check out f 06 error? Thanks
Posted by sanborns on
Anonymous
    President:
  • 1,937 Answers
Please see the following Whirlpool Service Manual for the Duet Washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Posted on Oct 30, 2009
F6 error code whirpool duet
The F6 error code for this model indicates a drive motor tachometer error. The control board is unable to properly detect the motor speed.
Jan 09, 2016 | Washing Machines
F 06 error flashing
The F/06 is:
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
The tech. should check these:
Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
Check the Drive Motor
Check the MCU
Check the Wire Harness
If you still get the error, replace the CCU.
Here is the part to order.
Nov 05, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Cod F-06
F-06 Drive motor Tachometer error
Possible causes/procedure:
1. Verify the shipping system including shipping bolts, spacers
and cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive motor and
Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
View the entire tech sheet here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet stops washing and blinks f then o6 repeatedly
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 - is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer shows F 06 and stops.
F06-Drive Motor Tachometer Error
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Nov 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f 06???? anyone???
f 06 Drive Motor Tachometer Error (The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high speed spin, the door will be unlocked after 3 minutes.
* Check wire harness connections between the Drive Motor/Tachometer and the Motor control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
* Check the Drive Motor
*Check the MCU
*Check the Wire Harness
I got this information off a website after searching for a F 02 error.
May 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT GHW9300PW4 F 06 Error Code
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove, reseat and reconnect every connector at least 3 times. Remove the motor control board, spray it down with electronic cleaner along with all connections by disconnecting them, spraying them down. Disconnect and connect a few times to ensure good contact.. It appears that spraying the board and connectors work.
Pl give me a ‘very helpful’ rating for the free help, thanks.
Mar 25, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
WHIRLPOOL GHW9150PW4 DUET WASHER DOESN'T SPIN AFTER START
F/06 Drive Motor Tachometer Error
  • Check the MCU
Mar 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code
The following link explains the "F06" error code:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
This is a motor speed error. It could be an indication of a failed drive motor, failed Motor Control Unit (MCU), failed Central Control Unit (CCU), or interconnecting wiring. I would check the motor windings first. If the motor checks good, the majority of the cases point to the MCU. Read through the instructions and take the readings as recommended to be sure. If you need further assistance, please let me know. I hope this helps.
Jul 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
899 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
