Question about Stanley Professional Backpack Poly 4-Gallon Sprayer #61804
MY STANLEY 61804 DOES NOT PUMP. THE PUMP HANDLE JUST POPS STRAIGHT DOWN EVERY TIME i TRY TO PUMP IT. ONLY USED 3 X. wHATS THE PROBLEM ???
Posted by purplepepper on
Anonymous
    New Friend:
The darker Seal has come off the plunger at the bottom of the unit , easy 5 min fix , just unscrew the allen keys at the bootonm take off the cover and remove the plunger , you'll see the plunger seal still inside you can fish it out with an allen key or similar tool clip it on again and reassemble
Posted on May 31, 2010
  • Joe Cordell Mar 04, 2011
    Good guess, iggiepal! Thanks!!
Anonymous
    New Friend:
  • 98 Answers
Sounds like your seal on the pump is shot.
remove the piston / pump handle and check the seal.
probably dried up and fell apart and you need a new one.
Posted on Feb 20, 2010
Stanley backpack sprayer top is stuck....... how do I get it off?
Hi Chris:
Seems a bit extreme to consider using the 12 gauge. I've found that a .22 works quite well. (Humour)
Hint! Pressurized tanks must have the pressure relieved BEFORE the lid can be removed.
If the lid has been over tightened or has stuck, you'll need to get more leverage to unscrew it. Sometimes a rag wrapped around it is all it takes.
You can also try pouring hot water over the cap. Lay the tank flat so the rim of the cap gets the heat. Wrap an old towel around it first so it gets a good hot soak.
Should come off without the artillery.
Cheers
Mar 19, 2016 | Stanley Professional Backpack Poly...
Parts sprayer stanley
I would like the answer yo that question
May 10, 2013 | Stanley Professional Backpack Poly...
I cannot get my bread pan out of the bread maker, no matter how I try to lift it! The instructions say to tilt it to the left and then pull- which did not work then I followed the suggestion of lifting it...
Most bread machines are held in by 2 little spring clips...one on each side.
They are under tension when the pan is in the oven and that is how it stays stable when kneading is taking place. So to get it out you have to release that tension and that is going take what I call the stern "pop". Grab the handle of the pan right in the center with both hands and put a little slack in it by lowering the handle down about an inch and then "pop" it straight up the little clips will release ther hold on your pan......magic!!
Sep 11, 2011 | Cuisinart CBK-200 Bread Maker
I need a new rubber seal for the plunger piston on my stanley backpack sprayer. Where can I get one of these? Is there a web site for ordering these parts?
Drive out to the country side and look for a ACE or TrueValue hardware store. Bring your sprayer with you. They will likely have the right part for you in stock.
Sep 09, 2011 | Stanley Professional Backpack Poly...
Need instructions for a stanley sharp shooter tr45 on how to load
at bottom back of stapler find the metal clip, about 1/2 x 3/4 inch piece. push in and down at the same time. after it releases pull straight out. insert staples, assemble in opposite order
Mar 06, 2011 | Stanley Tr45 Sharpshooter Light Duty...
Instruction,use,care manual not enclosed in box
call the 1-800 #
The manual is not available online.......Sorry
Feb 14, 2011 | Stanley Professional Backpack Poly...
I have a Stanly backpack sprayer pro 61804n and need a repair manual. Were could I find one. Thank You, Chuck
The picture looks a lot like a Solo sprayer I have. I wouldn't be surprised if Solo made them for Stanley. Do a search for Solo sprayers. They have a site. My sprayer is a Solo 425
Jun 21, 2010 | Stanley Professional Backpack Poly...
The spray unit bent and broke...
Lowes or Home depot sells replacement sprayers. Hose to tip all included.
Aug 18, 2009 | Stanley Professional Backpack Poly...
Stanley Professional Backpack Poly 4-Gallon Sprayer #61804 Logo
1,367 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
mpservices
Are you a Stanley Garden Expert? Answer questions, earn points and help others
