I am assuming that you want to display your laptop on your TV. Since you did not post what TV you have, I am listing multiple ways to connect your laptop to your TV. Just pick the right type connection that works for both your laptop and TV, connect OUT of laptop to an INPUT on your TV. Set your TV to that input (mode) and if you see nothing on the TV, look at your laptop keyboard at the F keys (function keys) for the one with a double display image on it, pree the function button and the F key to set the laptop to external display.
1. S-Video – This is probably the most common
method out there currently because an S-Video cable is cheap as heck
and just about every TV under the sun has a S-Video port. You’ll have
to make sure you laptop is equipped with this port. Remember, there are
two types of S-Video cables: 4-pin and 7-pin. Most
laptops and PC’s are equipped with a 7-pin port, so if your TV only has
a 4-pin S-Video port, then this method will not work.
2. VGA – If you have a HDTV, then you will be
better off connecting using a VGA cable. It gives much better quality
than S-Video and as with S-Video, the cable is very cheap. You usually
won’t find a VGA port on regular TV’s though, so this option is if you
have an HDTV.
3. DVI - DVI stands for Digital Visual Interface
with “digital” being the key word there. The digital signal will give a
higher quality picture than either S-Video or VGA. Of course, your
computer will need to have a DVI connection and your TV will need to be
an HDTV. This cord is definitely not cheap, it ranges anywhere from $40
to $80.
4. HDMI – Using HDMI will give you the best quality
by far. No computers that I know of yet have HDMI ports, but you can
get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible
with DVI.
5. Scan Converter Box – This is the last method
that I could think of and it involves using a scan converter box, which
takes a VGA signal and converts it into S-Video or component video.
If by chance you are attempting to hook up the TV to the laptop to capture video from the TV, you need to hook up your wire to the OUTPUT of the TV and you will need a capture card or hardware and software to do this. I hope this helps and good luck. Please vote appropriately and leave a comment.
SOURCE: how can i get a free manual for acer aspire
Go to:
http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012
To download a copy.
SOURCE: Acer aspire 5810t microphone does not work
it was the same with my pc
i istalled Win 7, after that the mic didn`t work. so i installed the driver for the mic again (can you get from the acer homepage)
after that its fine again. but now i have still a problem with my battery. its not that old and not used that often, but it has only 3h life when full charged....
anyone with the same problem?
SOURCE: I'm unsure how to restore
just to clarify: Restoring a computer to its original factory settings also cleans up the
C drive and removes all the viruses and old programs that bog down a
computer and make it slow and unresponsive. You can do it by following steps below:
Lucas
SOURCE: my acer aspire 5810t won't
There can be numerous problems when it comes to power and laptops.
With what I have dealt with in the past it is 1 of 3 things:
1: The charger is burnt out and can no longer sustain a charge for your laptop.
-You can test this by trying to find a similar charging cable and plugging it in to see if a charge is resumed. If a cable is not easily accessible, check and see if similar computers can recognize that the charger is plugged into them.
2: The battery is dead.
- If your battery is dead, you should still be able to turn the CPU in lieu of battery.
3: Power adapter connecting to mother board has unsoldered itself.
If none of these are applying to your situation, then this might lead to a bad HardDisk Drive. If this is the issue, you might want to take it to professionals to pull the information off the harddrive to save the data and you might need a new harddrive. Which are usually cheap in comparison to a new MoBo (mother board).
Hopefully this helps
SOURCE: how do I get into the fan inside the Acer Aspire
prepare equipment ( small screwdriver ) , just look back of your pc laptop..
sometimes fan the position of each laptop is different, you should look for it by opening with a screwdriver.Ok that it,good luck
