You have not said why that is....
Have you fully charged the battery prior to using in the car?
Using the power from the 12v plug in a vehicle will not "charge" the internal battery, but tends to maintain it somewhat. If the fuse in the end of the 12v connector plug is blown and the battery in the unit is low then this will cause the unit to shut down or fail to fire up.
Please check both, the units battery level and the fuse in the cig lighter plug and the plug that connects the unit to the cig lighter outlet.
Now the second half of your statement:
Nor by my battery
It is either not charged ( AC charger) or it has reached the end of its life which if used correctly is about 2 years. If the life of battery is shortened , then it is by a common practice of misuse. This misuse is to have the unit plugged to the car 12v when staring the engine.
1) it damages the battery life
2) It can and does damage the SIIRF chip, which is responsible for connecting to the satellites
I suggest that if it does not charge over a 10 hours Max period to its full state, then replace the battery immediately to avoid damage to the electronics from battery leak.
Thanks for using FIXYA
