Casio EXILIM EX-Z1000 Digital Camera Logo
Question about Casio EXILIM EX-Z1000 Digital Camera
My lcd will not display any pictures when i try to take them all i see is a black screen but no picture
Posted by bshuttera on
1 Related Answer
Misty Hoffman
  • 374 Answers
SOURCE: LCD works but no picture.
Sounds like you have a lens error. That is either going to have to be sent in or you will have to find someone in your area that can fix that.
Posted on Sep 10, 2008
2helpful
LCD Display is Black
the image in the LCD monitor will darken in strong sunlight or bright light. This is normal occurrrence in device CCDs and does not contitute a malfunction. This image will not be recoded when shooting still photos, but it will be recorded wihen shooting movies.Read you owner manual and adjust the MENU, according with your o. manual.Otherwise you must go the repair shop
God bless you
14helpful
Screen went black
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
1helpful
2answers
My sony dsc-w1 got very wet, caught in a rainstorm and did not have the case. I have left it dry out for 4 days and it turns on, lcd works, can read memory stick and display old pictures on the lcd. But...
Maybe the shutter got wet and sticky. You can try look into the lens then press shutter button to take picture. If you don’t see the movement inside the hole, the shutter doesn’t open, it will take black picture.
1helpful
2answers
Black screen
Try cycling through the Display button until you're able to view photo to be taken.
2answers
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
2answers
Lcd display for picture not coming on
Your LCD Display Might Have An Internal Screen Problem
8helpful
2answers
LCD Display Blank
CCD malfunction, common with Sony manufactured CCD chips. You are in luck, its a free repair regardless of warranty date.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=223&modelid=8044#
Feb 12, 2008 • Cameras
1helpful
Pictures are black
If you can display pictures in playback mode but screen is black in capture mode then the CCD sensor has stopped working and needs replacing.
2answers
Pentax Optio 555 LCD screen blank problem
No I don't believe it is your shutter, more than likely it is a LCD Screen problem. I would suggest you take your camera back to the shop where you purchased the camera and have it serviced under warranty. I had a customer with an Optio 550 come in and it looked like every shot was taken through 'venetian blinds' and the problem was with the LCD Screen and the camera was sent back to Pentax and repaired under warranty.
Top Casio Cameras Experts
David Shaub
Steve
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
