Question about Whirlpool AKZ159IX Oven
I have a Whirlpool AKZ451 built in oven that is not reaching temperature. The oven element appears to be working, could this problem be the oven temp sensor?
Posted by andypav on
daniel hendrickson
    President:
  • Whirlpool Master
  • 1,922 Answers
Yes, or the oven control itself,make sure also to closely inspect the element itself for any "HOT-SPOTS" where its getting a high resistance area and not passing all the current needed to heat the element
Posted on Oct 29, 2009
I have whirlpool oven akz451/ix/01. My element is square when I look for a new one they are all round ?? Will this work in my cooker ??
whirlpool service center /agent will have a correct element for your unit
the shape is probably for a more even heat distribution in the oven as it will cover the floor/ top area of the oven better
Nov 30, 2016 | Whirlpool Ovens
My whirlpool oven (AXP206/IX) is not reaching the temperature I want, 200c. It will only go to about 175c. Any ideas please?
are all the elements heating (glowing ) when on , ifnot then the ones that are not possibly need replaced .
Oct 28, 2015 | Whirlpool Ovens
My oven won't reach the appropriate temperature
It is a problem with neither of the two it is the sensor reads the oven temp and shuts off the heating element when it is reached, it is called the thermal probe or thermostat.
Jan 19, 2012 | Whirlpool Ovens
My AKZ451 oven has stopped heating up. The grill, light, fan is working fine.
You need to replace the oven element, located at the rear of the oven compartment, behind a removeable cover.
Oct 30, 2010 | Whirlpool AKZ159IX Oven
Whirlpool - akz451/ix/01 - Fan oven blowing out cold air
could be a blown element if not it could be a safety cut out or the stat
May 17, 2009 | Whirlpool AKZ159IX Oven
Whirlpool AKZ451 oven not working properly
If the fan is still working ,then you need a new oven element fitting, it will have blown, there by causing trip to operate.
Plz rate this solution .
Thanks.
Dec 12, 2008 | Whirlpool AKZ159IX Oven
Whirlpool built-in single oven AKZ451/IX/01
If this is an older oven, check to see if it has a control knob or switch labeled "manual and "hold". Make sure it's set for manual. The hold setting maintains temp at about 140 degrees.
If not the case, is this gas or electric?
Nov 11, 2007 | Ovens
Whirlpool AKZ159IX Oven Logo
677 people viewed this question
Top Whirlpool Ovens Experts
Michael Thomas
Michael Thomas
John Tripp
John Tripp
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
