Question about Canon BubbleJet i560 InkJet Printer
Canon 1560 error - orange light blinking 5 times
Hi there, my Canon i560 has suddenly stopped working. Printed fine yesterday, not today.
The orange light blinking is 5 times then holds on green for a moment, before orange blinks again 5 times, etc.
What does this mean? Thanks!
Posted by gogomax49 on
Anonymous
    President:
  • 787 Answers
It's mean "Print head not installed/Defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number now is QY6-0064, because the old QY6-0042 is discontinued.
Posted on Oct 30, 2009
  • Henk Bosschaart Nov 19, 2012
    Hi Ivanov, I cannot remove the cartridges, because the head will not slide to the center position after power-on. I'm not convinced i can manually pull the printer head after opening the cover......???
Henk Bosschaart
    New Friend:
Hi Ivanov,
Posted on Nov 19, 2012
When I turn on my Canon i560 printer the light blinks orange and green and will not print anything. I've tried to turn it off and on, unplug it and nothing seems to be working. What can I do to fix it?
try this. It is the reset for the waste ink error (8 flashes)
1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the
power button.)
2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then
release the Resume button and Power button.
3) The green indicator flashes during initialization.
When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message.
(The indicator toggles between orange and green each time the Resume button is pressed.)
4) Next, press the Power button, and the green indicator will light, and the function will be executed.
5) Turn off the printer then back on and error should clear.
Aug 04, 2010 | Canon BubbleJet i560 InkJet Printer
The orange error light is flashing 5 times in between the green light.
Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jan 27, 2010 | Canon BubbleJet i560 InkJet Printer
My Canon i560 stopped printing- snall window
That error says the purge assembly is not moving properly, check for paper stuck over on the right where the printhead parks, also if the squeegee is stuck over the cleaning pads you need to push it back to allow the pads to come up properly.
Jan 10, 2010 | Canon BubbleJet i560 InkJet Printer
Canon i560. It stopped printing when i changed black ink cartridge. None of the maintenance functions work. They all show the same message: Press resume, then turn printer off & back on. 1st green...
Blinking 5 times in orange means print head not detected by the printer. You may try following procedure: remove and reinstall the print head. If the problem not solve find good print head to compare. More information please check below link
Blinking in orange 5 times
Oct 18, 2009 | Canon BubbleJet i560 InkJet Printer
The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
My canon i560 had error 6000. What is?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ptttq20
Jun 25, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Blinking orange 5 times and 1 green
Try this:
Most of the time when a printer used for a certain period the ink would dry out and caused an error message. What you do is to replace with a new inks pad inside the printer and reset that error message. Once it is done, your printer will work again!
For Printer Model: Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000:
1. Turn off printer
8. Your printer should respond as normal.
Please remember to rate all Techs who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 04, 2008 | Canon BubbleJet i560 InkJet Printer
THE PRINTER IS BLINKING ORANGE FIVE TIMES ORANGE AND THEN ONE TIME GREEN
u cradige has been short so u have do this inestert new cardige & try to pritnt your problem will solve
Jul 12, 2008 | Canon BubbleJet i560 InkJet Printer
Canon i560 Ink jet Error Code 5C00
1. Turn off printer
May 05, 2008 | Canon BubbleJet i550 InkJet Printer
Canon i560
may be ink level is too low,check it first,make sure delete the all pending documents
regrads
prasanna
Mar 07, 2008 | Canon BubbleJet i560 InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
1,736 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
