Question about Canon PIXMA MP180 All-In-One InkJet Printer
Printer displays error U052 - Canon PIXMA MP180 All-In-One InkJet Printer
Posted by svvod on
Craig Gillette
    President:
  • 2,306 Answers
U052 says the printhead is wrong, you need a new printhead, the part number is on the side.
Posted on Oct 29, 2009
3 Related Answers
alpug
Danilo Baraquiel
  • 1961 Answers
SOURCE: Printer displays error U052 saying: The type of
Error U063 appears when the printer detected that the ink cartridge was refilled or the ink level reach its limit.
To remove this error you need to reset your printer. Follow this procedure
1. Disconnect the printers power outlet. 2. Press and hold the STOP/RESET button (red circle with a triangle) while connecting the power outlet back. 3. While holding the STOP/RESET button, press and hold the POWER button 4. Release the STOP/RESET button while still holding the POWER button 5. While still holding the POWER button, press the STOP/RESET button twice 6. Release the power button 7. When the indicator light COPY Green - press STOP / RESET button 4 times 8. Restart your printer.
Let me know how it goes.
Posted on Apr 18, 2011
Anonymous
  • 837 Answers
SOURCE: Cannon MP600 error message U052
hi there,
The dreaded U052 error means that the 'chip' fitted to the Cartridge is not responding .. Canon (like all printer mfgs) makes all it's profit from selling Ink .. so they fit these chips to try to prevent you refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and (it seems) the chips are particularly sensitive to static / damage .. many people end up blowing the chips during the swap over .. or even when fitting the original genuine cartridges to a brand new unit for the first time ...
If the unit is brand new, take it back and demand a replacement ... if you have just swapped over the chip onto a compatible cartridge, you can try buying a genuine Canon cartridge (which will have a new chip) = hopefully that will do the trick
Posted on Jan 16, 2009
Q4SteveB
  • 159 Answers
SOURCE: Canon MP530 U052 Error
NB. I have seen some suggestions that canon's have a 'Service Mode' that allows you to disable the cartridge chip checking and allow you to print no matter what .. however I've never found any details ... perhaps some-one else has the details ??
Posted on Mar 22, 2008
Canon Mp550 error after i cleaned the print head with soft dry tissues and re install it .U052 the type of print head is incorrect.
A common experience among users of various Canon inkjet printers. The lawsuit settlement is close to being finalized so join soon.
Canon USA Inc Consumer Class Action and
http://www.federmanlaw.com/Websites/federmanlaw/images/QUESTIONNAIRE.pdf
"...at least 16 different Canon printer models have been identified that display an error message of "U052: Wrong Printhead Error," after limited use. This error indicates that the printer does not recognize the printhead, or that the printhead itself is faulty, but disables all functions of the printer, including scanning and facsimile capabilities, rendering the printer unsuitable for its intended purpose and use."
Dec 27, 2014 | Canon Office Equipment & Supplies
What is Canon printer Pixma MP560 error U052?
Canon printer class action suit
Jul 03, 2014 | Canon PIXMA MP560 CLR INKJET P/S/C/F FB WL...
How to fix u052?
Error U052 = Please check that print head contact pins of the carriage are not bent.
Or else you may need to replace
- Print head
- Carriage Unit
Jun 29, 2014 | Canon MG5150 AllInOne Printer
Errr u052 cannot print .
A lot of Canon printer's users come across with the error message, "U052 This type of print head is incorrect." It is a very common error on Canon printers and is fairly easy to troubleshoot.
There are two different scenarios related to U052 kind of error message.One is where the print head is not installed at all and then it is giving the 'U052 This type of print head is incorrect' error message.
And, the second scenario is where the print head is installed nut it is not functioning properly or probably not working at all. The below section will show step by step troubleshooting of both the scenarios.
Jun 19, 2014 | Canon MX882 All-In-One InkJet Printer
U052
To try and resolve the U052 error on your PIXMA MP550, please remove the ink tanks and print head from the printer, then reseat them. If you still experience the same issue, please turn off the printer, unplug the power cord from the back and leave it out for at least 10 minutes, then plug it back in and turn it back on. If the issue is still unresolved, unfortunately, the printer will require servicing to resolve the issue.
You can contact Cannon here: Canon Contact Us
This information originally from: My printer Canon MP530 stopped working with an Canon Forum (also has a walk through for removing the printer head and ink cartridges.)
Just so you know, the 530 and 550 are the same machine, except the 550 has a few small improvements.
Mar 31, 2014 | ErrorExpert
Canon pixma mp630 error u052
FYI, Canon inkjet printer class action suit
Mar 29, 2012 | Canon PIXMA Office Equipment & Supplies
Canon MP660 U052 Error
Remove and reinstall your Printer Cartridges. Else, you will need to take your printer to a Canon Service Center to have them replace your faulty Print Head / Temperature Sensor that is causing the U052 Error.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Oct 24, 2011 | Office Equipment & Supplies
How do I deal with the Check Cartridge U052 message
Solution 1:
  • Remove and replace the cartridges.
Solution 2:
  • Insert new cartridges
Solution 3:
  • Reseat the print head to correct print issues or clear an error.
Solution 4:
  • The print head is broken and it must be changed by a new one.
Source:
http://fix-your-printer.blogspot.com/2010/11/error-u052-on-canon-printers.html
Sep 16, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Error code U052 how do I get rid of it for good?
U052 is a temperature sensor in the works below the cartridges. Canon can ship you the part; it's not the inks cart, but then it's not for me to say 5 minutes with the power off or 20 with either a solvent cartridge (especially on any colors with stripe dropouts) or cleaning the works and reseating flex cables won't fix it. (Take it to a Canon shop per any surviving repair warrants; it's serious enough.)
Sep 10, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon pixma mg5220 wrong printhead error u052
Were you aware of the Canon printer class action suit?
May 24, 2011 | Canon Pixma MG5220 InkJet Printer
Open Questions:
See all Canon PIXMA MP180 All-In-One InkJet Printer Questions
Canon PIXMA  MP180 All-In-One InkJet Printer Logo
1,836 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
