I have nec washing machine error E9
Either drain is clogged or pump is jammed or faulty.
Clear drain and screen. Check pump for jams. Make sure there is power going to pump with a voltmeter.
If you have any other questions, feel free to ask.
Here are some diagrams, tips, and more if you need them.
www.repairclinic.com/RepairHelp/RepairHelp.aspx
www.acmehowto.com/howto/appliance/washer/washer.php
home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Hello Lahoma, thank you for your post!
I understand that your Frigidaire washer fills with water, will not drain completely, and is flashing an "E10" error code. The error code stands for your washer fill time is too long. This could be an issue with your water valve, main control, or water pressure. You should check to make sure that your water flow is normal and that your water line is not restricted. This could cause an issue with the way water is distributed within your washer. The water pressure coming into your washer should be at 30 PSI. You can also clear out any false error codes by performing a reset on your washer. In order to reset your washer you need to disconnect power from it for roughly ten minutes. If this does not help resolve your issue I would recommend consulting with a professional technician for a proper diagnosis to be completed. I hope this information is helpful to some degree. -Matt
