Nikon LS 2000 Film Scanner Logo
Posted on Oct 29, 2009
Nikon LS 2000 scanner is reporting a hardware error
Nikon LS 2000 is reporting a hardwared error. The error message gives the following number - Sense:0x04620000
jmjdk
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 27, 2009
jmjdk
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1337
Points
Hello Mike,
According to a previous post this is your answer by:
johnmichaelc
The symptoms of stepper motor failure are a loud grinding noise during scanning followed by the enlightening message:
"The scanner has reported a hardware error. The present function cannot be continued. Sense: 0x04620000"
The Nikon LS 2000 Film Scanner says the stage locking screw is still in place but it was removed 10 years ago when I bought it. I tried to put the negative film adapter in, it didn't work. Then I put the...
The lubricant has become sticky and is acting more like adhesive than lubricant. This is the most common cause of malfunction in the LS-2000 and LS-30 scanners. It's a quite curable condition.
Nikon LS-2000 and LS-30 film scanner service and repair is available. Check seller pjferrante2 on eBay. Scanner performance backed for 12 months. Very reasonable price.
2helpful
2answers
I am getting a notice saying hardware error Coolscan V ED
you must perform a p.o.s.t. reset. That is:
1) switch off the scanner
2) swithc off the PC
3) disconnect scanner from PC
5) remove the dia/film adapter
6) switch on tyhe scanner and wait untill it booted
7)insert the film/dia adapter
8) connect scanner and PC
9) switch on the PC
it should work now......
3helpful
2answers
The scanner has reported a hardware error. Please reset the scanner by switching on and off. If this does not work please contact your local nikon service or support service office
Maybe this refer also the hardware faulures on a nikon 5000ED. I managed to repair them my self after being mischarged a couple of times at NIkon repair centre.
Please see some solutions I added on
www.scancare.nl/scanner.html
Different problems regarding a nikon 5000ed were shown.
regards
Andries Bos, www.scancare.nl
1helpful
3answers
My LS-2000 film scanner has just stopped working
I read this forum entry and it solved my problem also:
http://www.pcreview.co.uk/forums/thread-1936922.php
Nikon LS-2000 scanner gives error 0x04620000
Stepper Motor Failures
Within the first 6 months of purchase I had to return the scanner twice to replace the stepper motor. The symptoms of stepper motor failure are a loud grinding noise during scanning followed by the enlightening message:
service required to fix stepper motor
5helpful
2answers
"The Scanner has reported a hardware error..."
Version:1.0 StartHTML:0000000105 EndHTML:0000008195 StartFragment:0000002796 EndFragment:0000008159 Normal 0 0 1 464 2648 22 5 3251 11.0 0 21 0 0 I brought a coolscan 9000 the last month without the film holders, software etc just the scanner. A friend of mine sold me it for a good price. I run Leopard in a Powerbook G4 15” 1.2 ghz 2 Gigas ram. I installed the Nikon scan 4 and when I open it the scanner report an error: The Scanner has reported a hardware error... every time that I run the program this message appears. I thought that this was because I hadn’t got the film holders. When the film holders arrive from USA the same problem appears : The Scanner has reported a hardware error... Them I tried Silverfast Software. In this case the scanner report another error: there are not film holder ( or something like that). I uninstalled Nikon Software with the same utility to install it. Reinstall the Software and the same ****** problem. When I switch on the scanner a loud noise came from inside, after this the blinking light stopped and nothing happen ( no calibration, no light inside, nothing). Just one thing. The Scanner has reported a hardware error...
I checked on internet and the solution of switch it of and on doesn’t work. CALL TO THE NIKON SERVICE that’s was my only solution.
Of course I didn’t . The price of the scanner was 300 Pounds.
SO I OPENED IT.
I REMOVED THE SCREWS FROM THE BACKSIDE AND FROM THE BOTTOM OF THE SCANNER. I TOOK THE METALLIC CASE OF: PICTURE 1. After a while looking everything without touch I’m start to check for the connection cables one by one, WHEN DISCOVER THAT ONE CABLE PLUG THAT GOES FROM THE SCANNER TO THE FIREWARE BOARD WAS DESCONECTED…. PICTURE 2 Maybe on the shipping this plug looses his place. SO I SWITCH ON THE SCANNER AND THE PROBLEM DOESN’T APPEAR. Now the problem was that the film holder wasn’t recognising from the scanner. So I followed the steps that most frequently indicate on the web:
1-Close the scan program –
2-Turn off and unplug the scanner
3-Plug the LS9000 back in and turn it on
4-Reopen the scan program
The scanner worked. When I switch on the scanner take a minute or so to calibrate and determinate the film holder. Them I open the Nikon Scan 4 and every looked nice. I could scan my first negative ALELUYAAAAA. So I close everything without the screws so I put the scanner vertical to put back the metal case ones I finished I turned on the scanner and the Nikon program. For my surprise the same ******* error I couldn’t believe it.
I opened it again and I found the cause of the problem . BECAUSE THE SCANNER WAS ON VERTICAL BEFORE, THE METALLIC GUIDE THAT CONNECT WITH THE SERVO WAS MOVED (Move the scanner from one place to another may cause this issue) So with my finger I putted it in the same place. THE SCANNER WORK’S.
After this the only problem was a big loud gnashing and grinding noise that I sorted with CELOTAPE BETWEEN THE TWO PIECES THAT WAS SEPARATED BEFORE.
PICTURE 3
Now the scanner work fine. Sorry for my **** English and I hope that someone can find useful this information.
Install Nikon Scanner LS 2000 on Windows XP Professional
Scanners made for DOS based systems seldom work with HTFS systems.
There were some fixes attempted but generally a no go situations.
You could try the following
Start/Programs/.Accessories/ programs
Compatibility Wizard and set the computer to run as Win 98 with this particular software.
5answers
Nikon LS 2000 hardware problem
Here's what you need to do (carefully!!):
www.vad1.com/photo/dirty-scanner/ls2000-cleaning/
2helpful
Hardware error
the problem is that the scan sledge gets stuck if arriving at end of screw. To fix:
Open scanner by unscrewing the four screws in the back - this will allow ypu to slide the sides slighly backwards and then remove. Then take the plastic front of (press the plastic tap on top with screwdriver). You will the see a small brass screw center bottom at the front. Loosen this a few turn and try again (you may have to try a few times)...
Good luck
3answers
LS 2000 w/SCSI connection
does the nikon scan sofware recognise the scanner ?
Top Nikon Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
