Icom IC-R5 Handheld Scanner Logo
Question about Icom IC-R5 Handheld Scanner
My kenwood TK1118 cannot do manual frequency setting. Even the "FUNCTION" button didnt do anything. I wanted to set the freq. to 462.6225MHz so that i can use it with my Motorola T5720 set
Posted by hazree2007 on
Anonymous
You can press fuct and # ( St : 10 or 12.5 or 25 ) then adjust frequency like t5710
Posted on Dec 03, 2009
  • fredray Jun 28, 2011
    Switch TK1118 off. Press function key, do not release, switch on, frequency is displayed, adjust frequency using keys as required. Press PTT button to confirm frequency.
How do I puy the freq. in my bearcat210xlt?
Press the "Manual" button. Enter the frequency using the number keypad. Include the decimal when entering the number. Press "E" to set the number. Press "Manual" to move to the next channel and enter the next frequency. Continue until you have entered all of the frequencies
Read more : http://www.ehow.com/how_7198180_program-bearcat-210-scanner.html
My kenwood walkie talkie tk1118 transceiver cannot change channels or frequency cause it is lock. How to unlock?
Try turning the unit "on" while at the same time pushing another button.Try this with each button.
12helpful
2answers
Require Frequencies for CTCSS codes for Motorola GP 2000
check this link at page 21 or see below
CTCSS PRIVACY CODES FREQUENCY CHART (Hz) Code Freq. Code Freq. Code Freq. Code Freq. Code Freq. 1 67.0 9 91.5 17 118.8 25 156.7 33 210.7 2 71.9 10 94.8 18 123.0 26 162.2 34 218.1 3 74.4 11 97.4 19 127.3 27 167.9 35 225.7 4 77.0 12 100.0 20 131.8 28 173.8 36 233.6 5 79.7 13 103.5 21 136.5 29 179.9 37 241.8 6 82.5 14 107.2 22 141.3 30 186.2 38 250.3 7 85.4 15 110.9 23 146.2 31 192.8 8 88.5 16 114.8 24 151.4 32 203.5 * Channel 8,9 and 10 are designated Canadian Marine Frequencies * Channels 8~14 are low-power FRS license free channels Note: Privacy codes can be programmed for use on Channels 1~22 only
3answers
Changing tuning frequncy from odd to even No. Kenwood KDC-MP228
Most car stereo (stereos in general) won't tune to even numbers. If you're having problems tuning in your station then you're either too far away or you should take a look at your antenna.
2helpful
2answers
Help me put new Frequencys in my scanner
Here is the link to all Uniden scanner manuals:
http://www.uniden.com/index/manuals_results.cfm?cat=3
Also, you can find the frequencies for your area at www.radioreference.com.
What will i do to connect Motorola T5720 and T5728
Set both the frequency and the interference eliminator code to match one another. (The big number and the small number) Here is a link to the owners manual: http://www.motorola.com/mdirect/manuals/T56XX_57XX_User%20_Manual_E.pdf
Basic instructions:
Press the Menu Button
The freq number will flash
Use the + or - button to select the frequency.
Press the PTT button to save the channel setting.
To set the code:
Press the menu button until the code starts to flash (the small number)
Press the + or - to select the code.
Press the PTT to save the code setting.
Once you have both radios matching on frequency and code, they should communicate together.
I have a Kenwood KDC-W311A car radio/cd, and am having problems setting the preset stations. It insists on doing an auto search and whizzing thro' the frequencies @90 mph. I know there is a way to do a...
Apparently there are 2 modes in which to use the MENU function, Standby & Tuner mode. The manual doesn't make this very clear. However, Manual Tuning can be aceived by putting the radio into TUNER mode, then pressing the MENU button for a couple of seconds & scrolling thro' with the Control Button until you can set Manual Tuning to ON.
1chab0d
1helpful
Turner mode
To the right of the number 6 station preset is an auto/name button. In the display it likely shows something like auto 1 or 2. each press will cycle it through Auto 1 > Auto 2 > Manual. You want the manual setting. See if that works for you.
43helpful
4answers
Programming Bearcat BC 55XLT Scanner
Ok doc, I'll see if I can walk you thru this as there don't seem to be a manual available for download.
* Push manual button and bring it around to channel #1
Enter the freq including the decimal point. Push the E button to enter the freq into the first channel.
* Push manual again and move to channel #2 and repeat.
If you need some new freq's for your area, go here, click on your state, county, and it'll give you a complete rundown.
http://www.radioreference.com/apps/db/
If you need 10 codes for your area, go here and click on your state.
http://www.nat-com.org/radio.htm
If you need anything else, let us know,, Mechanic
Operator/instruction manual
ghilger, First off, has your radio been converted to open up all the other channels(including CB)?? That has to be done first, or it's locked in the ham freq's. I think the factory manual is pretty well detailed, but i've been around radios my whole life. The mode button does the changing from am/fm/usb/lsb.Here's from the manual;
MODE: Operating Mode. Press the MODE control to select the operating mode. The operating mode is indicated on the liquid crystal display: am, fm, usb, or lsb.
* See, there is 2 different functions for each button. One set of functions are by just pushing the buttons, the other set of functions are obtained by pushing the function button first. The function button is activated by pushing in on the clarifier knob.
*Here is for saving of freq's;
Memory Save. To save in memory a specific
frequency and operating mode, select the desired mode and rotate the FREQUENCY control to the desired frequency. Press the FUNC button, and then press the M.SAVE button. S will appear on the LCD next to the frequency. While S is displayed, immediately press any of the memory channel buttons (1 - 5). The mode and frequency is now saved into memory. If the S indicator disappears before you press the memory channel button,
the information will not be saved and the process
must be repeated.
M.LOAD: Memory(Recall). To recall, any of the saved memory channels press the M.LOAD
button. L will appear on the LCD for several seconds. While the letter is displayed press the desired memory channel button (1 - 5). The programmed mode and frequency will be displayed.,
If you have any more questions about the radio, repost them here and I'll try to walk you thru them. The radio is a very good ssb rig, especially set up with a power mic. Hope this helps,, Mechanic
Top Icom Radio Communications Experts
Robert McClure
Steve
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
