Question about Toshiba TEC B-572 Printer
I think the printhead needs replacement
I think the head needs replacement because there is a lines missing when I print bar codes. The missing lines are consistent between labels coming off the row , ie the image is missing in the same place.
Boise Idaho
    Sergeant:
  • 219 Answers
It sounds as if the print head needs cleaning. Follow the instructions in section 10.1 of your manuaI If you don't have a manual you can get it here - http://www.toshibaprinters.com/technical_information/technical%20info.htm. If the cleaning doesn't work you will need to replace the head.
Posted on Oct 29, 2009
Testimonial: "Good job - easy to use and will recommend your site to my customers. "
6ya staff
SOURCE:
Zebra 110Xi III Plus Printing Bar Codes too dark
if it is the least setting for print head then you may need to dry ribbon by putting in sunshine for few hours
Apr 23, 2013 | Zebra 110Xi III Plus Thermal Printer
There are gaps in my printing!!! The docs are missing lines...Is it the printheads or could it be an ink problem?
Yes it might be a problem with the print heads. You can try cleaning printheads under tools menu. After cleaning printheads click on Align Printer in Tools menu and that will solve your problem. If not then you might need to replace the printheads. If you these print heads are less than 2 years then HP will replace it for free.
Apr 19, 2011 | HP Officejet Pro L7680 All-In-One Printer
The printer will print a bar code but the reader will not read it. the reader reads the bar code from a second printer just fine
Sounds like there are some elements worn off of the printhead causing some of the bars to not be printed. To test, create a label that prints a thick black line or solid black box across the width of the label (assuming a 4" label). Any vertical white lines that show indicate elements that are not functioning.
You could also put one label above the other, lining up the barcodes and you'll probably see bars that are missing from the label that won's scan.
The only ways to correct the problem are to install a new printhead or move the barcode field on the label so that the missing elements fall in the spaces between the bars.
Hope that helps !
Apr 08, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Lines on print. There's are three lines on picture print only. Can't see the line on document. It's about 1/4 inch wide and going throught top to bottom.
Have ou gone into your menus. Into troubleshooting, then image quality.
You will want to run both the eliminate light stripes and eliminate smears procedures. that will purge the print head, blow air through the jets and hopefully resolve the problem. I do believe the 8550 has a Jet Substitutin procedure where you can do a workaround and make other jets make up for the light areas.
here are some directions, Will forward more
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Page], and then press the [OK] button.
  4. Evaluate the 'Light Stripes Test' page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. The 'Light Stripes Test' page is the last page of the Troubleshooting Print Quality Page that printed.
    WARNING: To avoid injury, do not touch the sharp metal strip attached to the clear rubber wiper blade in the Maintenance Kit.
  5. Use a clean lint-free cloth or a new paper coffee filter to gently clean the maintenance unit's clear rubber wiper blade, use only a wiping motion across the entire length of the wiper blade, and then empty the waste tray. A dirty maintenance kit wiper blade can cause white lines and weak or missing printhead jets.
  7. Repeat step 3 to reprint the Troubleshooting Print Quality Pages. If there are no missing or partially missing color bars then the print quality problem has been resolved. If there are missing or partially missing color bars then the printhead cleaning procedure will need to be performed. Continue with the next section.
To clean the printhead using the basic eliminate light stripes procedure:
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Basic], and then press the [OK] button. The printer will perform a head cleaning, which will take about five minutes. The printer will then print a cleaning page and a light stripes test page.
  5. Repeat steps 1 - 4 one more time. If there are no weak or missing jets then the print quality problem has been resolved. If there are still weak or missing jets after two basic light stripe cleanings, continue with step 6.
    NOTE: Do not try the Advanced Eliminate Light Stripes Cleaning mode without performing two basic cleanings first.
    To clean the printhead using the advanced eliminate light stripes procedure:
  6. Press the [Up] or [Down] arrow button to select [Advanced], and then press the [OK] button.
  7. Select the missing jet color and number. If necessary, check the light stripes test page to determine the color and jet number of the missing jet.
    NOTE: Only perform the advanced light stripe cleaning once. If weak or missing jets still persist, continue with step 8.
  8. Print the Troubleshooting Print Quality Page. Evaluate the Light Stripes Test page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. If necessary, perform the basic eliminate light stripes procedure one more time. If the Advanced Eliminate Light Stripes procedure does not resolve the weak or missing jets, perform the Enable Jet Substitution Mode. See the Related Items below.
Feb 05, 2010 | Xerox Phaser 8550DP Printer
Lines throug bar code, unable to scan
First of all, clean the printhead.
if the lines are from top to bottom, some dots in the print head are broken. Replace.
If the lines are from left to right, check if the ribbon is loaded correctly, if yes, proceed to clean the printhead, and every part that are in contact with ribbon.
This problem is not a heat problem, set the temperature to 0, in order to save printhead.
Jan 12, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
All of the sudden my bar codes are not fully printing. Missing some lines on the bottom. Also the numbers are not printing rel clear. Have ran this label before and no problem. Now it is all bar codes.
Try cleaning the printhead, then print the zebra test print. (see user manual) or just print a solid black box 4" wide by 1" long. If you have white vertical lines through it you may need a new printhead.
If print test is good try increasing the heat/darkness setting
Nov 09, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Followed instructions for i860 error5200 and now get a new issue
You will need a new printhead, you only remove to see if that's the problem, wrong or missing cartridge error means the printhead has gone bad.
Aug 28, 2009 | Canon PIXMA MP130 All-In-One InkJet...
ERROR 41 ON BROTHER mfc 3820CN - PRINT HEAD
This is definitely the print head. You will need to purchase a new print head and install this. It is very easy to install all that you need to do is lift the printer lid and extract the ink cartridges. The printhead is the black part under the ink cartridges and on either side of it is a lock and release bar. push these down and out wards to loosen them and then lift the print head out. replace the print head and then you will need to input the print head ID in maintenance mode on the printer. Turn the printer off and hold down the menu/set button and power on. You will here it beep and all the lights flash on the panel. The punch in 68 2580 I think from memory i could be wrong but just look it up if you can get hold of a service many and then enter the new printhead code and 99 to exit. Done Hope this answers your question.
Jul 03, 2008 | Office Equipment & Supplies
Oki 520 missing print
You have replaced the item which is commonly the cause- the printhead. The other possible problems are: a connection break in the printhead ribbon cable, which makes electrical connection from the driver circuitry to the printhead. Look for a tiny crack, especially along the edge of this ribbon cable. Another possibility is an electronic component defect in the circuitry which fires the printhead, or maybe a loose solder connection in the same circuit. Lastly, when you replaced the printhead, are you reasonably certain the replacement head didn't have a broken top pin or two?
Apr 10, 2007 | OKI MICROLINE 520 Matrix Printer
Toshiba TEC B-572 Printer Logo
274 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
CheckitRight
CheckitRight
matt
matt
STEVE
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
