Kenmore Elite 45986 Front Load Washer Logo
Posted on Oct 29, 2009
Every time I start my Kenmore HE2t washer there is
Every time I start my Kenmore HE2t front load washer there is a very powerful smell of mold. I can't find the manual but I suspect there is a filter that needs cleaning. Any suggestions?
ahuyffer
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 8 Answers
  • Posted on Oct 29, 2009
ahuyffer
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
8
Questions
Helped
2570
Points
22
If it has a clean cycle that says, "Bleach Only," run it with 1/2 cup bleach right in the machine. If not, run it on the longest, hottest cycle you have. In the future, leave the door open slightly between loads.
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
2helpful
3answers
Kenmore HE2t only runs some modes
Take the front panel off the bottom and look for a clear bag with the tech sheet in it. It has the tests that you need to run. The old models of this make had issues with the whole control panel and it is not cheap
I have a model #110.47561601, Kenmore HE2t Front load washer Type 832. I am getting a code of F-24, when I try to start the cylce. What is the problem that prompts a F-24?
Hello
F-24 is a water temp snsor error.Try running the machine in spin and drain.Once empty unplug machine for 3 min.Then try load of wash again.This time use cold water until error clears.
1helpful
I have a he2t wash comes out smelling like mildew really tired of it please do not tell me to leave the door opened I do still smells
The trick is to clean the interior using regular detergent, baking soda, and hot water; run a complete cycle without any laundry in it. Wash the rubber boot where the door seals with same mixture at which point the interior should smell fresh and clean. Now is the time to leave the door open after use so that the remaining moisture can evaporate out to prevent mold growth. Hope this helps!
2answers
My Kenmore Elite smells like mold!
Run a cycle ,no clothes in, with about 3 cups/ 750 ml of bleach in it. How? put a fil a plisticbag with the bleach and set it in the washer. It will tip up when you start the cycle. You should end up with a clean washer and clean empty bag.
Persistent mold and mildew smell, even though door is kept open and I live in an arid climate. Any solutions?
every front load washer evetually will start to smell,the best solution ls run your washer with hot water and put a container of clr in the washer it will wash all the residue built up on the outer tub
2helpful
Sour smell coming from washer even when door is
If you have a front loader it will hold water around the seal of the door and after time it will mold and start to smell.
Front load washer mold smell
Run an empty load of Clorox water. Put double in and run the complete wash & rinse cycle. It will kill the mold spores. Keep the lid open when you're not using it.
Bad mold and smell from washwe
i have repaired appliance most my life i tested soaps and softer,at our own family shop,i can tell you that washers do not make mold or bad smells either does cloths its what and how much product that you are pulling in the washer that is molding and smelling and it stays in cloths building up load after load,i have a kenmore he3t front load washer i use 1/3 cup powdered only.armen hammer only. non he only.my washer inside is spotless smells clean and fresh all the time, you will need to clean yours inside out with bleach then use affresh weekly switch to 1/3c powered soap
1helpful
3answers
Mold & Smelly in Washer
Shepherd, Finkelman, Miller & Shah, LLC, is currently investigating defects and other problems in certain front-loading washing machines manufactured and/or sold by Whirlpool, Kenmore, and LG Electronics, including Kenmore Elite HE3 front load washers, Whirlpool Duet front load washers and LG Tromm, LG XL and other LG model front load washers, which result in the growth of mold/mildew in the machines and which can cause the staining of clothes and other problems.
On August 29, 2007, SFMS filed a Complaint against Sears Holding Corp. involving its Kenmore HE, HE2, HE3, HE4, HE5 and other front-loading automatic washers. If you own a front-loading washing machine that is manufactured by any of the above-mentioned companies and are experiencing the growth of mold/mildew in the machine, visit the following website: www.frontloadwasherclassaction.com
Alexander
vince
