Question about HP Compaq Thin Client t5515 (pc538a#aba) Network Terminal
Citrix environment cant print .pdf files(Adobe reader) but users can print emails, excel or word docs. Black ink covering entire page when users print .pdf files.
Posted by armindo_card on
Jeff Bosset
    Sniper:
  • 93 Answers
Uninstall and reinstall Adobe Reader.
Posted on Oct 29, 2009
How do I download information when I click on a link it says "no apps are installed to open this type of file/
This is not a question of Google Gmail but rather about opening the types of files you are trying to open (and naturally on what type of device). There are many types of file attachments including Word (doc, docx), Excel (xls, xlsx), PowerPoint (ppt, pptx), Adobe Reader (pdf), etc. You must have the appropriate application installed to be open each specific type of document.
Sep 15, 2014 | Google Gmail
Canon pixma mp287
Are you sure the correct printer is selected in Excel? I would compare Excel print settings with Word settings, since Word is printing docs.
Dec 08, 2013 | Office Equipment & Supplies
First page of PDF files is printed in 10% size - rest of document is ok
Sir/Mam,
Does this happen with a word file, or a web page, or outlook, excel
please check. if OK with them its the file its bad. Mite want to upgrade the adobe to 10 or 11 current. Try different computer also. Print different adobe files also.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 17, 2012 | Konica Minolta KONICA BR BIZHUB C451...
Unable to clean says to consult maintance chapter in users guide i dont have user manual model mfc=215c
Here is the link to the main Brother support page for your printer:
http://welcome.solutions.brother.com/bsc/public/eu/gb/en/doc/manual_index.html?reg=eu&c=gb&lang=en&prod=mfc215c_eu_as&dlid=&flang=English&type2=-1
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000453/BH3eLowBase_UkEngUsr.pdf
To view the Support Page or the User's Manual just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, and then just follow the onscreen instructions to install it.
See page 138 of the ONLINE USER'S MANUAL for detailed instructions on how to CLEAN THE PRINT HEAD.
Basically it reads:
Press INK MANAGEMENT.
Press UP or DOWN ARROW to select CLEANING.
Press MENU / SET.
Press UP or DOWN ARROW to select BLACK, COLOR, or ALL.
Press MENU / SET.
The machine should now clean the print head then go back into standby mode automatically.
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Apr 14, 2011 | Brother Office Equipment & Supplies
In yahoo email i cant open a linked attachment. this is a brand new computer.
Hi Smith.
To be able to open attached docunebts the related program must e installed on your computer.
As an example:
If an attached file is a PDF file (eg. xxx.PDF) a pdf reader must be installed - typical Adobe.
Can be found here:
http://www.adobe.com/downloads/ - download the Adobe Reader and install it.
If the document is a word document eg xxx.doc or - xxx.docx - Microsoft Office must be installed and so on.
The problem might be as descried that the related program is not installed on your computer.
Regards
Feb 02, 2011 | Computers & Internet
Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly...
Help with PDF Documents Some documents on Maine.gov are provided in PDF format. In order to view or print PDF documents, you need the free Adobe Reader. Generally, you will find an alternative format is also provided for the document, such as Microsoft Word, HTML, or plain text. If you cannot access a document in PDF format and there is no alternative version, please contact the agency or contact the Maine.gov webmaster for assistance.
Adobe PDF-to-HTML Online Conversion Tool
We've provided solutions for some common PDF issues below.
General Tips: Problem 1: Blank Page in Browser You have selected to download a file and you receive a blank page with a "Done" message at the bottom of the browser. This may be because you do not have enough space in your temporary internet file folder to complete the download.
Solution: Internet Explorer: Tools> Internet Options> Temporary Internet Files> select Delete Files
Netscape: Edit> Preferences> Under Category on the left Advanced> Cache> click Clear Memory Cache
Problem 2: Blank Page "%PDF" You received an error message containing "% PDF" or you have received a blank page while trying to download. This is due to a problem with your web browser not opening .pdf documents correctly.
Solution: Adobe Acrobat Reader 5.0: Edit> Preferences> General> Options> Web Browser Options> make sure the Display PDF in Browser box is not checked.
Adobe Acrobat Reader 6.0 and newer: Edit > Preferences > Internet > make sure the Display PDF in Browser box is not checked.
Problem 3: "Error Locating Object Handler" You receive an error message that says "Error Locating Object Handler" while trying to download a document. This is because there is a dependency with a plug-in for Adobe Acrobat while using Internet Explorer.
Solution: Please go to the following website for detailed instructions: http://support.microsoft.com/default.aspx?scid=kb;EN-US;q262213
Problem 4: Unable to Print You have successfully downloaded the pdf, can view it on your computer screen but are unable to print. This is due to a post script error with your printer.
Solution: In any Acrobat Reader program: File > Print > check the Print As Image box > OK
Problem 5: "Adobe Reader could not open file" You received the error message "Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly decoded).
Solution: Adobe Acrobat Reader 6.0: Edit> Preferences> Internet> make sure the Display PDF in Browser box is not checked.
Aug 26, 2010 | Computers & Internet
I don't know if I need to download Adobe Reader. What is it for? I use my computer mainly for emails.
If you download and install Adobe Reader, you can see .PDF files like insurance cards for your automobile for instance. Emails don't require .pdf file capability, usually, but traditional printed documents available online are usually put into the .pdf file format.
Jul 04, 2010 | Toshiba Satellite A135-S2276 Notebook
Links do not work in Pdf saved file
Don't panic,many people face this problem.You can use a third-party tool,such as advanced word to pdf 5.0,It is good in preserving the formatting.
source:http://www.advancedpdfconverter.com/products/wordtopdf.html
Jan 11, 2010 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
Lexmark Z645 can print locally, but will not print off of citrix
Lexmark X and Z series printers do not function in a Citrix environment, see page 4 on the following document.
ftp://ftp.lexmark-europe.com/brochures/de/solutions/citrix_basic.pdf
Apr 13, 2009 | Lexmark Z645 InkJet Photo Printer
HP Compaq Thin Client t5515 (pc538a#aba) Network Terminal Logo
478 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
