Question about GE WSXH208A Front Load Washer
How do you get the door on my LG front loader to unlock? The door is open but the lock is engaged and i cannot shut the door.
Posted by the5pos on
Anonymous
    New Friend:
  • 112 Answers
If you lift the lid(unscrew the soap dispencer) look for a thin red or green colored plastic cord. pull on it that should unlock it
Posted on Oct 29, 2009
The door on LG front loader washing machine won’t unlock
hi Margaret.
If the washing machine malfunctions or you need to stop the cycle and retrieve the clothing, you can force the door to unlock.
  • Open the door after the "Door Lock" indicator turns off. ...
  • Press the "On/Off" button, if the washer is not already on.
  • Select the "Spin Speed" button to turn on the Drain & Speed cycle.
  • or go to this link and have a read up.
LG front loader washing machine wont unlock Google Search
Dec 12, 2017 | LG Washing Machines
The door on my lg washing machine will not open even when indicator light goes out
top loader or front loader
faulty door lock safety switch
unplug from wall .. if no luck
going to have to force it and replace the damaged parts
Jan 22, 2017 | LG Washing Machines
LG frontloader WD-1238c door locked
Unfortunately it as to be open from top take power off open top normally two screws at the back slide cover off look inside front loader for door catch unscrew and done open door replace with new one same model connect wires as disconnected take pics before disconnect screw it back on done.hope it helps you
Jan 10, 2018 | Washing Machines
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
Front door does not release
press the pause/ play button. This will unlock the door
Jul 11, 2009 | LG WM2688H Front Load Washer
Washer will not completely spin dry . clothes left lying in water. We have checked the water supply hose screen and it is not plugged.
Your door lock switch (not the one that turns your "door locked" light on) which allows your spin cycle to engage is probably not engaging properly. This is usually caused by the failure of the motor which locks the front washer door, and not this switch. As you know, that door is difficult to open even when it is unlocked so there is really no need for it to be locked.
Therefore, instead of spending a pile of money tryng to resolve this problem, make sure it does not happen again by tricking the machine into thinking the door is locked.
To do this first remove the front washer panel. Then remove the front screws which lock down the top cover. This gives you access to this switch. Fold up a piece of stiff paper and jam it in next to this switch so that it alwatys gives a "door is locked" signal to the machine control board.
Your machine should now operate and spin properly.
Of course the washer door will always be unlocked while the washer is operating but my door has never flopped open after making this repair. It certainly beats paying $200 for a replacement control board, and even more if something is also wrong with the locking motor. Remember that any replacement board will be just as junky and defective as the original board was.
Always remember, when you get ready to buy a new washer, not to buy any front loaders, because they are all poorly designed and therefore, because of the cheap materials used overseas in making them, they all rapidly become mechanically defective.
Good luck.
Jun 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front loader washing machine will not go through spin cycle. door locked shut. cant get clothes out
most frount loaders have and unlock pull ring on the door latch switch, it will mean removing the bottom access panel to reach up inside the machine and pull the release ring down to unlock the door
Apr 21, 2008 | Washing Machines
Maytag Neptune Washer Door Locked
INSIDE THE SOAP LOADER THERE IS A LIME COLOR STRING PULL IT WILL UNLOCK LATCH
Apr 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Mar 02, 2008 | LG WM1812C Front Load Washer
GE WSXH208A Front Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
