Question about Maytag MAT13MN Top Load Washer
Has there been any changes in it's hook-ups recently ?
The reason I ask is this, there are alot of variables that can cause unbalanced rinse cycles/washer's, one being if your water lines are reversed, hot tap to cold inlet and cold tap to hot inlet, you can experience an unbalanced situation in the rinse when "hot" water is introduced instead of "cold" water.
That, or you may also have extremely worn damper pads, oil on the chassis base, un level machine/floor, overloading, or several other possible senario's to cause an out of balance situation.
That's a start. Hope it helps, let me know please.
Good Luck
Posted on Oct 29, 2009
