Upper couper pipe conescted to the heat pump of panasonic cu-4chv11np lools loose at connection point, and there are gas leak. How to fix? How much is to regas?
Posted by ntaliayakov on
Anonymous
  • 534 Answers
The fix is going to entail a silver solder weld due to the high pressure the line holds. As far as cost to recharge system it is up to the a/c tech that does the work but the cost should be around 150 to 200.00 depending on the ease of repairs. Good Luck on repairs
Dave
Posted on Oct 29, 2009
Sump Pump Ejector line (outside) freezes.
IF the drain on the outside of the home is in the ground and is not below the freeze / frost line, it needs to be changed. If the drain is above ground at any point it needs to be unhooked at the point it exits the structure and diverted to the ground with an elbow. A splash diverter would be placed under the elbow.
Jan 09, 2018 | Washing Machines
Frozen sump pump ejector
what part of the world do you live in
Jan 12, 2014 | Washing Machines
Need diagram showing Heater Hose connection points. Upper heater hose connects to a pipe along the left front side of engine which travels dow the left side and elbows torwards the radiator under the...
try the scrapyard and look at one in their ,or ask a local owner that is just parking up in a supermarket and look at theirs .lots of different ways to overcome this problem but if the pipe has beeen disconnected its because the heater matrix is no doubt leaking
Nov 03, 2011 | 1993 Cadillac DeVille
1/2 hp shall well pump. set at 30/50....seems to hesitate around 48 for an extra amount of time....have to shake the hose or tap the pressure plate to get pump to cycle off. also....noticed the pump...
50 PSI for a 1/2 HP pump is approaching the upper limit for that pump. Many things can affect the upper limit. How far the pump has to pull water up the well pipe, is there any air leak what so ever on the input. If the pump lost its prime because it could not attain the 50PSI, I would suspect it may be just outside the limits of the pump at this point in time. If this pump is on a shallow well, it may be that the shallow well point is beginning to plug and not allowing as much water in which would cause a harder pull for the pump. I would turn the high pressure side down to maybe 45 and see if it operates properly at that pressure.
I hope this helps.
Jun 22, 2010 | Flotec Corrosion Resistant Shallow Well...
Loose Gas cap indication with check engine light. Replaced gas cap and leak detector pump with no change. Solenoid tested ok.
IF EVAPORATIVE PURGE SOLENOID NOT THE FAULT.CHECK ALL VACUUM HOSES CONNECTIONS.OR FUEL FILLER PIPE COULD HAVE A LEAK.
Jun 05, 2010 | 2005 Jeep Grand Cherokee
As soon as you put in water it leaks everywhere
There are many possible points that the leak can be.
Most posible is from water tank to the pressure pump then connected together with plastic pipes which they brake or loose.
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
May 15, 2010 | Saeco Vienna De Luxe Espresso Machine
Please discribe where is the thermostat in a 95 cutlass ciera?
follow upper radiator to center of engine between heads at center of transmission, thermostat inside the housing that upper radiator hose connected to, its between motor and exhaust pipe crossover
Feb 09, 2010 | 1995 Oldsmobile Cutlass Ciera
How do i change a water pump in a 97 grand am with a 2.4 litre engine
2.4L Engine
See Figure 3
  1. Disconnect the negative battery cable.
  2. Drain and recycle the engine coolant.
  3. Disconnect the oxygen sensor wiring.
  4. Remove the upper exhaust manifold heat shield.
  5. Raise and safely support the front end of the vehicle securely on jackstands.
  6. Remove the exhaust manifold brace bolt.
  7. Unbolt and remove the lower exhaust manifold heat shield.
  8. Break loose the manifold-to-exhaust pipe spring loaded nuts.
  9. Unbolt the radiator outlet pipe assembly from the water pump cover.
  10. Disconnect the exhaust pipe from the manifold.
  11. Pull down and back on the exhaust pipe to disengage it from the exhaust manifold bolts.
Do not rotate the flex coupling more than 4°. this could damage the component.
  1. Separate the radiator outlet pipe from the oil pan and transaxle.
    1. On manual transaxle, remove the exhaust manifold brace.
  2. Next, leave the lower radiator hose attached and pull down on the outlet pipe to detach it from the water pump. Allow the outlet pipe to hang.
  3. Lower the vehicle.
  4. Remove the exhaust manifold-to-cylinder head nuts.
  5. Extract the manifold, seals and gaskets.
  6. Remove the timing chain cover. Refer to the procedure later on in this section.
  7. Remove the timing chain tensioner. Refer to Timing Chain removal later in this section.
  8. Unbolt the water pump from the cylinder block.
  9. Extract the pump assembly-to-timing chain housing nuts.
  10. Remove the water pump and cover assembly.
  11. Separate the pump from the cover.
  12. Clean all mating surfaces of gaskets and sealant materials.
To install:
Prior to installing the water pump, read the entire procedure. Pay special attention to the tightening sequence to avoid component damage and ensure a proper seal.
  1. Attach the water pump to the cover and hand-tighten the components.
  2. Lubricate the splines of the water pump drive with chassis grease or equivalent, then install the pump and cover assembly. Hand tighten the cover-to-block bolts.
  3. Install the pump-to-chain housing nuts and hand-tighten.
  4. Lubricate the O-ring on the radiator outlet pipe with an anti-freeze solution and slide the pipe into the water pump cover, install and hand-tighten the bolts.
  5. With the specified gaps, tighten in sequence as follows:
    1. Pump assembly-to-chain housing nuts
    2. Pump cover-to-pump assembly
    3. Cover-to-block, bottom bolt first
    4. Radiator outlet pipe assembly-to-cover
  6. Install the exhaust manifold using new gaskets.
  7. Install the manifold-to-cylinder head nuts, follow the tightening sequence and tighten to specifications.
  8. Raise and support the front of the vehicle.
  9. Index the exhaust manifold-to-exhaust pipe flange bolts.
    1. Turn bolt bolts in evenly to avoid cocking the exhaust pipe and binding the bolts. Turn the bolts in until they are fully seated.
  10. Install and secure the radiator outlet pipe to the transaxle and oil pan.
On manual transaxles, install the exhaust manifold brace.
  1. Install the timing chain tensioner and chain cover.
  2. Attach the lower heat shield.
  4. Attach the exhaust manifold brace. Tighten the manifold-to-exhaust pipe nuts to specification.
  5. Attach and secure the upper heat shield.
  6. Connect the oxygen sensor wiring.
  7. Fill the radiator with coolant water mixture until it reaches the heater hose coolant outlet, then install the hose and continue to fill. This will assist with the complete cylinder block fill.
  8. Connect the negative battery cable.
  9. Start the engine and top off the cooling system and check for leaks.
Dec 28, 2009 | 1997 Pontiac Grand Am
Ac not working
if you by passed the relay and clutch engaged then this shows that pump works ??but was it getting cold on and around the restrictor valve where the pipes enter the cab is normally a valve block but american monsters use a valve in the pipe for cooling and if its not getting cold their or blowing cold inside cab then system needs re-gassing with R 134 gas if its an older system with R 12 gas then it will need to have adaptors fitted to valve connections and refilled with R134 gas.The main cause of A/C system loosing gas is porosity in the rubber flexible pipes also the back seal on the pump.Or just regass and put a leak stopper in the system
Sep 01, 2008 | 1998 Chevrolet K1500
How can I fix my Kenmore portable washer 100.49722990?
Most common cause for water leak
is around the water level sensor connection, a small hose from the tank bottom rear, to the control panel, if loose or removed it is a small constant leak. if loose snip 1/8 inch off the hose refit and pull a zip tie around it tight
if it were the drain hose or pump, it would usually be a very large leak that increases when the pump is running and floods the laundry
Jun 21, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Heating & Cooling Logo
90 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
